Question about GPS
My Garmin street pilot C340 randomly powers off. There is the required 12V coming outh the end of the power cable. After the event, some time later it will start working again.
Well if its like mine which is a garmin, it has a charging flaw it can only be charged while off, and if you wait for your battery to get so low it shuts off, your screwed cuz now its gonna take forever, basically powere up befor long journeys, turn off while not in use and allow to charge, if your at the point where it turns off, RETURN IT, you may have to wait days for this unit to com back to you, and dont go on long trips unless you have a way of getting back i was screwed on a 3100 mile trip, more like disaster but good luck to you
Posted on May 11, 2010
Seems to be dead .wont turn on when plugged into the cigarette lighter Garmin street pilot c 510
Before writing the unit off as dead I would try obtaining a new 12v power cable and maybe try your cable in someone else vehicle, often the 12v power in your car can short not providing power to the GPS.
Hope this helps!
Apr 13, 2011 | Garmin StreetPilot c510 Deluxe GPS...
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Street Pilot c340 mount
Try a hard reset using the reset button under the silver trim on the front. Pull off the trim ring by hooking your fingernail under it right below the logo.
If that doesn't work, then take the unit off of the mount for a better look at the contacts. Re-seat the mount onto the unit and see if that helped. If the mount is damaged, consider getting a friction mount instead of the suction cup. For about $40 you'd get new power contacts and a new cord, and the unit would sit on your dash instead of falling off the windshield all the time.
All of this is assuming that the problem occurred suddenly after a fall, and that your battery is still good.
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Updating Garmin
Hi my garmin Street pilot c340 doesn't show a screen ,it'ssayn "enter a pin" i dont know wat to dou vith that thankyou.
Jun 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
62 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
