Question about GE Dryers
Our Profile (natural gas) dryer stops the cycle with time remaining. It doesn't completely shut off, but the cycle stops and the remaining time is shown on the digital display. We have cleaned the hose and vents thoroughly, but it hasn't solved the problem.
  • mary_schoen May 12, 2010
    I haven't heard back from Rylee about this problem, and the initial solution wasn't suitable for the problem we are having. Please help!!! My clothes are only getting half-dry because the dryer (natural gas) just stops partway through the cycle. It is perfectly level (checked that again yesterday), and the vents are totally clear of lint.
    President:
  • 1,382 Answers
Hi, On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all or it will stop in mid cycle. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Thank you!
Posted on May 12, 2010
    If the fuse can't be re-set, then that's not the problem. You can't immediately hit start again, but after awhile you can. Simply unplugging the unit for a minute or two, then re-plugging it back in doesn't cure the problem, but time seems to. Are there other sensors that do re-set on natural gas Profile dryers? Thank you.
  • Prakash R May 12, 2010
    A gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and in dryers that use a glow type of ignitor, a flame sensor. If the flame sensor fails, the ignitor may not go off and the gas flow will not start and may stop during mid cycles.
    The easiest way to diagnose the flame sensor is to observe the burner operation. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
    For testing purposes, the sensor should show continuity at room temperature and no continuity when it is heated by the ignitor.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the dryer is hot at the beginning but cold at last then the coils have gone bad. If it doesn’t heat then you’ll need to check the igniter, check the continuity which should be under 100 ohms. If not then igniter has gone bad. If yes, then check the continuity on the flame sensor. If everything above is fine then please check that there is no lint around the burner. Please replace whichever has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 11, 2010
  • mary_schoen May 11, 2010
    It's not a hot and cold issue. The cycle simply stops -- stops blowing, stops turning -- but the power does not go off. It just stops, and the remaining time is displayed on the digital readout. It's plenty hot when it's working -- it just won't complete the cycle. It appears to be some kind of sensor shutdown.
  • Rylee Smith
    Rylee Smith May 12, 2010
    If you have already checked the vent and cleared everything then check these:
    There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
    Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
    Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
Kenmore gas dryer works but no heat, model# 110.20702990.
make sure the exhaust vent is not plugged. shut gas off, disconnect hose, start dryer. stop and reconnect hose turn gas back on and try again.
also a propane dryer can work on on natural gas but it is very dangerous to run a natural gas dryer on propane because the orfice is too big.
Sep 23, 2009 | Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE DPGT750 Gas Dryer runs but no heat
if your blower motor isn't getting up to speed it won't heat.check troubleshoot mode by holding my cycles and help at the same time for three seconds.may need a new blower motor
Mar 09, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
