Question about Panasonic PT-D5600U DLP Projector
Total Expected life (in hours) of a Panasonic DLP Projector
I'd like to know the total expected life in hours of a Panasonic DLP Projector (such as a PT-5500U). I know the lamps need replacing at 1500 hours (or 3000 hours for long life lamps) but I'm told that after a certain amount of hours, these projectors start to have problems, like color being off, that cannot be really be affordably fixed.
  • 4,234 Answers
The projector lifetime has a lot to do with maintenance and environment. Over time, the LCD panels will start to deteriorate. I worked for a rental company where these units were in constant use. After 5 years, they were still going strong. Realize though, that these were highly maintained: constant cleaning via compressed nitrogen to remove dust, lens cleaning and filter changing on a regular basis. Checking for proper fan function and complete disassembly and checking for connections etc.
A word of caution: DO NOT work with the LCD block unless you have access to a clean area and have training. The tolerances here are very small. Slight changes can severely alter the picture quality and all adjustments should be left to a professional.
Hope this helps,
Dan
Posted on May 11, 2010
Testimonial: "Thanks for the detailed response!"
Why has the picture on my samsung 62 inch dlp been getting increasingly darker
Projection bulbs provide a high-intensity light. Most have an approximate 2000 hour life. This can vary greatly depending upon factors such as how often you turn it on and off and how often and how well you clean the filters. As the bulb begins to reach its life expectancy, it will start to get dimmer. A 2000 hour hour bulb, if it reaches that time frame, is expected to be putting out 50% (half) of the brightness that it did when new. It may simply be time for a new projection bulb.
Sep 03, 2014 | Televison & Video
Convergence Bad
Changing the convergence IC's could cost $300-$400 total.CRT based TV rear projectors are more or less obsolete now,with everything going to DLP and LCD.These days 5 years is the expected life on these TV's (most extended warranty contracts only cover up to 5 years)
Sep 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
HD20 switches on by itself
the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp. Good luck.......
Aug 02, 2010 | Optoma HD20 DLP Projector
Comp screen to projector, bulb light turns on
Try resetting the lamp hours it can go into a safe mode if you exceed the expected life of the lamp. It can be done even if there is no image have a look at the infocus website all models vary on the procedure if not try a firmware update to wipe its brain but you will need the leads it was shipped with.
Feb 11, 2010 | InFocus Work Big IN32 DLP Projector
How do you reset the lamp after installing a new one.
Restart the projector. Press and hold the Exit and arrow up buttons on the projector for 5 seconds to display the total used lamp time. Press Auto on the projector or on the remote control to reset the lamp hour to ?0?. Wait about 5 seconds to let the OSD disappear.
Oct 21, 2009 | BenQ MP611C DLP Projector
What would cause a Christie to shut off after 60 secs?
On my Vivid Lite the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp.
Jun 04, 2009 | Christie DS+60 Multimedia Projector
Panasonic PTAE 700U optical block
Are you referring to the bulb? If so it depends on total hours used...a common bulb use is 3000 hrs. That is if it has not had rough usage....which was the case with our projector at The Salvation Army Citadel / church. If the projector is turned off before properly cooling is allowed...the life span of the bulb diminishes quickly......God bless, Capt. Hannu
Dec 29, 2007 | Sony XL-2100U Projector Lamp for...
Reset timer
FROM THE PROJECTOR
Press and hold the EXIT Button for 3 seconds to display the total used lamp time.
Then Press the MENU button on the projector during the lamp hour message.
The press the <-- or ---> button to reset lamp hours.
Press EXIT to leave.
Nov 15, 2007 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Panasonic PT-D5600U DLP Projector Logo
192 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
