Question about Apple Power Mac G5 Desktop
I have an apple macbook pro with a slot load optical drive. I am trying to burn a sony dvd rw the drive accepts the disk then makes a few whump whump noises spins the dvd then ejects it. It will play a normal dvd though
    President:
  • Apple Master
  • 1,619 Answers
Go to about this computer and make sure that rw - or + is supported by your drive.
Posted on May 14, 2010
Why can't I get a home dvd to load to my MacBook Pro?
https://itunes.apple.com/gb/app/free-dvd-ripper/id625150797?mt=12
Feb 27, 2013 | Apple MacBook Pro Laptop Computer with...
Macbook pro disc drive ejects everything
Try using a cd drive cleaning disk. Costs around 15 dollars.
Dec 18, 2012 | Apple MacBook Pro Laptop Computer with...
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
MacBook pro 08 idvd will not burn to blank -R dvd
Go click on the apple logo at the top left of the screen. Then click on About this mac. Then click on More info. Then click on Disc Burning.
It will tell you what DVDs the optical drive will burn. If no info shows up, then you got a bad connection or need to clean the optical drive laser lens or your optical drive is about dead so you may have to buy a new optical drive.
Feb 18, 2010 | Apple MacBook Pro Laptop Computer with...
My mac keeps ejecting any dvd i put in?
Because this could go in the way of a hardware issue or be an issue with the types of DVDs you are using (even legal and commercial copies), so I have three procedures below, I would suggest you try, in order to resolve your Macbook issue with auto-ejecting DVDs.
Procedure #1
-PRAM RESET-
The Parameter RAM Reset is a good troubleshooting process for working with various functions including refresh rate, screen resolutions, and DVD region issues to name a few.
Steps:
• First, shut your Macbook down properly
• Once your Mac is shutdown, locate the following keys on the keyboard:
Command, Option, P, and R.
You will need to hold those keys down simultaneously .
• Now turn on the Macbook.
• Press and hold the Command-Option-P-R keys.
• You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook to start up.
Run the next procedure (below) from within your Mac OS X Desktop.
font.f1 {font: 13.0px Myriad Pro} Procedure # 2
-RUN DISK UTILITY -
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utility run this repair permissions until completion
Once Disk Utility is complete and there are no errors in red in the completion summary, quit Disk Utility.
Proceed to the last procedure.
Procedure #3:
Check this Apple support page for Macbooks and make sure your Macbook is update on its firmware and SMC updates:
Apple Macbook Support page
•Now try a few types of DVDs, commercial, burned and blank DVDs and if you have different brands of blank DVDs make sure to try them as well.
Apple has done it best, by providing a great support page, that I would like to provide you as a final troubleshooting support option:
Apple Support Link:
Troubleshooting the slot load optical disc drive
You have your work cut out for you, but not to worry, follow these procedures listed in this post and in the links I have provided and you will have an answer as to if the issue with the DVDs auto-eject from your Macbook, is a hardware, software or DVD disc issue.
Regards,
-Mactechtrainer
Jan 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
MacBook Pro often will not recognize commercial DVDs
Go to MAC's website and see if there are any driver updates for your MACBOOK Pro.
Oct 25, 2009 | Apple Genuine Pioneer "SuperDrive"...
MACBOOK PRO SuperDrive Reads somes Recorded DVDs fine but some appear as empty while in other mas are fine
some pioneer dvd models have firmware upgrades to solve problems with some DVD brands - check your model and visit the pioneer components website - I have a DVD reader which worked better after the firmware upgrade - try this site http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVRZ44G&upd_id=1692&os_id=16
May 28, 2009 | Apple Genuine Pioneer "SuperDrive"...
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Optical drive
Are the disk you are using, are they burned CD/DVDs from a PC? Perhaps the CD/DVD is not fully burned. We get CD/DVDs that after sticking them in a PC find out that Nero was used and the finalization part of burn was not executed because they potential were going to add more to the disk.
Jul 13, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple Power Mac G5 Desktop Logo
112 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
