Question about LG Washing Machines
Excess water in drum, water wont drain. getting a code of OE.
    President:
  • 1,382 Answers
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Thank you !
Posted on May 11, 2010
Wont drain?
Check the pump filter which could be blocked or something like a nail has jammed the pump impeller. this may cause a mess as the water needs to be drained to access the removable cover to gain access to the filter/impeller.
Also check the drain pipe is not blocked. this can also be used to drain the machine into a bucket manually.
Apr 28, 2015 | Washing Machines
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
WF203ANW OE Code..still
I had a piece of rubber stuck round the actual pump very hard to see had to take pump out and clean it totally
May 23, 2013 | Samsung WF203ANW Front Load Washer
Washer now shows OE on progess window after i tried to wash bathroom rug. Would not spin/drain excess water and door won't open.
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine that has an OE error code.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2010 | LG WM-2077C Front Load Washer
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
Washer has water still in drum and OE on digital readout
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 17, 2010 | LG WM-2277HW Front Load Washer
Front loader wm2277hs washer with OE error sign
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
Error Code OE and Door will not unlock
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Dec 16, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
