Question about Frigidaire FAH085N1T Air Conditioner
Do you need brackets for outside wall installation for the frigidaire 15000 btu air conditioner.
  • 82 Answers
No you do not. Not a bad option, but if wall sleeve nstalled properly this unit will not need brackets.
Posted on May 11, 2010
Suburban air conditioning
googled:
"suburban air conditioner 15000-48254C966" and got specs right here:
http://www.adventurerv.net/coleman-15000-btu-roof-air-conditioner-top-unit-p-1332.html
good luck.
Sep 03, 2014 | Electrical Supplies
I have a dometic rv unit 15000 btu what is the amp draw?
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
Aug 19, 2011 | Dometic Rooftop RV Air Conditioner
My landlord installed this brand new out of the box. Our apt is 900 sq ft tops. This unit can't even cool down our living room and kitchen. If the whole 2 bedroom apt is 900 sq ft, you can imagine how...
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
Jun 07, 2011 | Maytag M6X08F2D Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
We live in a non studded home, can the walls support a 24,000 btu aircondition with support outside on the wall only?
What are the walls made of? Some details there would better help us t advise you on what to do. Also, this being a window unit, why not just mount it in the window?
Aug 02, 2009 | Frigidaire FAS255J2 Air Conditioner
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Does the Frigidaire FAC 126P1A need to be vented?
It must be installed in a window openeing or through the wall.
A load bearing wall is no problem.
Cutout the opening larger than the unit and install a header in the wall cutout.
Mar 12, 2009 | Frigidaire FAC126P1 wall/window Air...
Using a Wall Air Condtioner in Window
It is called a mounting kit and can be purchased at Home Depot, Lowes, or an appliance store.
Sep 29, 2008 | Frigidaire FAC124 wall/Window Air...
Have no outside window sill to support
Purchase an "L" shaped shelf bracket (heavy duty of course) and fasten it to the outside wall under the window. You should be able to now use the support bracket against it. You can even get special plant hangers that will serve the same purpose. I have seen many people do this and it seems to solve the problem!
May 30, 2008 | Kenmore 6000 BTU Single Room Air...
Frigidaire FAH085N1T Air Conditioner Logo
172 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
