Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My hotpoint dishwasher is making a loud noise when its in use, What could be the reason for this???
SOURCE: Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Posted on Jul 25, 2008
SOURCE: Dishwasher Making Loud High Pitched Noise.
Problem is with the main pump motor bearing. Water leaking from the face seal enters the front bearing. After some time, the bearing wears out bringing on the loud noise. The motor is easy to remove but the bearing requires some time to remove. I did not have access to a press so I ground off the bearing an replaced it with a shielded 8mmx22mm type. Grainger p/n 1L001. The part is only $9 compared to over $200 for a replacement motor. It takes some time and disassembly of the dishwasher can be difficult but take your time and be ginger with the parts. The root of the problem seems to be the impeller. It screws onto the motor shaft and seems to work loose after time. Since its tightness compresses the face seal, when it loosens water can seep. No way to lock it in place after tightening. Weak design point.
Posted on Sep 24, 2008
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 93 Answers
SOURCE: HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
Posted on Mar 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Making a loud noise like it's stuck while going through the wash cycle....can't seem to get the inner workings of it unbolted...
If the washer is making loud noise then there might be two reasons:
1.The Bearings of the spinning assembly went bad.
2.There might be some garbage and needs cleaning.
Dec 08, 2009 | Kenmore Dishwashers
Does not feed any water just sounds like its doing something but not
Without the model number i cannot tell what type of hotpoint dishwasher it is. If it still makes a noise when the door is open then the anti flood device has been set due to water ingress to the bottom of the dishwasher.
If you disconnect the dishwasher from the mains and after pulling it out, gently tip it back (you will need some towels at the back of the appliance), you may see water pouring out of the bottom.
If this is the case and it then works then you will need to call a engineer to locate the reason for the water ingress.
Regards
Aardvark Repairs
Nov 16, 2009 | Hotpoint Dishwashers
We have a Hotpoint Dishwasher HDA3400Go2WW in our two year old home. It has been very loud from the start. We are thinking of replacing it because it is so loud. Is there anything we can do to it to make...
Dishwasher noise is such a pain, especially in a new kitchen that you need to leave just to have a conversation.
There is nothing to be done to make the dishwasher quieter. Upgrading is the way to go. I now own the amazingly quiet LG LDF8812ST which works well for me and is EnergyStar rated. I really did not know the dishwasher was running, and visitors often comment on how quiet it is as we chat around the kitchen table.
But it takes time to get used to a water and energy conserving dishwasher. You need to make sure the arms are not blocked with each load and not use ultra-cheap detergent powder. Also, the plastic items will not dry like the older dishwasher.
Good Luck!
Apr 11, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher made a popping noise and all the lights...
the connection at the bottom of the dishwasher where the house wiring meets the dishwasher wiring is probably melted. you would need to cut back the burnt wires and re-splice it..
Mar 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
HDA3400G020WW noise
Mar 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Noise from dishwasher
Dishwasher makes loud noise in begining. How do I remove lower spray arm to see if something is stuck? Whirlpool DU1055xtpb4.
Jan 14, 2009 | Whirlpool Dishwashers
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
217 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
