Question about Toshiba Satellite A135-S2276 Notebook
How 2 reset the cmos password for toshiba A135-S2276
WithOut soldering, how can i set my cmos password?
    Sergeant:
    Champion:
  • 236 Answers
Short a couple of times the battery terminal while every thing is unplugged
Posted on May 11, 2010
Bios password toshiba Sat A135 cannot reset???
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to remove the battery on your Toshiba laptop as it is soldered on the motherboard.
Feb 08, 2011 | Toshiba Satellite A135-S2276 Notebook
Tip
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Please help me !! i need Toshiba A135-S2276 PW cmos default .
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 04, 2010 | Toshiba Satellite A135-S2276 Notebook
How to removed a toshiba satellite a135-s2276 password from bios
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Real time clock loses time even while running off of AC. So, I don't believe it is a CMOS battery issue? The model is Toshiba A135 S2276 running Vista Home (32). Also, I have the dreaded self-assigned...
If you once take bios battery out the password issue will be reseted , the time zone of the date and time settings will changed , set the correct time zone first after that set the present timing, the time zone will be available in the time settings window itself , try it you can definitely fix it.
Oct 30, 2009 | Toshiba Satellite A135-S2276 Notebook
BIOS Password reset on Toshiba A135-S2276
Use a boot disk such as, the Ultimate Boot CD or the Ultimate Boot CD for Windows if you don't need a BIOS password. If you do, try Toshiba.
Oct 20, 2008 | Toshiba Satellite A135-S2276 Notebook
Need a password...
Found these instructions on another website...
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Hope this helps
Regards
Aug 18, 2008 | Toshiba Satellite A135-S2276 Notebook
USB Ports Not Working
Check your CMOS settings to ensure that your USB ports are enabled.
Oct 15, 2007 | Toshiba Satellite A135-S2276 Notebook
Reset Toshiba Labtop A135-S2276 Bios Password
see the below post for a possible solution http://www.fixya.com/support/t187128-toshiba_m105_s3004_bios_password
Aug 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
