Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Not chaging any ideas or where i should start
  • 3,740 Answers
Before you start check the wires on the left side of the air shroud of the engine. That is the rectifier assy and if one of those wires is broken it will not charge.
Here is what the book says.
7bccnot chaging any ideas or where i should start - ad5bf82.jpgass=
That is pretty much it without using the Kohler specialty tester for the charging system.
Thanks for using FixYa.
Kelly
Posted on May 23, 2010
Zanussi iz16s door does not lock once programme has started i have chage the door lock sytem it clicks and light comes on but the door will still open any ideas ?
give it a swift kick, that should do it... or tip in on its side... and if that doesnt work just burn it and cut your losses!!!
Oct 29, 2011 | Zanussi IZ161S Front Load Washer
MY 1998 DODGE NEON WONT START. I WAS TOLD TO REPLACE THE CAM SENSOR AND DID SO. THE COIL WAS CHECKED AND ITS GOOD. WHAT IS THE PROBLEM
I bought one with the same problem, the mechanic chaged: camshaft sensor (it was ok), the coil pack (was ok too), the pcmodule( ok too) the arness (ok) and did not start. I checked timing belt and was ok. but wen I did the compresion test , every cilynder was too low ( 10 30 an 0), my firsth idea was head gasket replecement,and wen was remooving the camshaft sprocket Bingo: the small pin was broken (that means that the camshaft sprocket was not align in time) Had to chage the head an the camshaft both in terrible shape. bad lobes and cam bearings worn out. wen I crancked it start at the first time. PD. the head wasnt craked, the head gasket was good too and the valves ok .
Nov 27, 2010 | 1998 Dodge Neon
1981 yamaha midnight special 850cc. starter button and kill switch not working but lights etc are working. no power from the start button. battery fully chaged? started after chaging the throttle cable.
If no power going to kill switch check Ignition fuse, sidestand ,clutch & neutral switches.
If all OK suspect the starter cut-out relay
Ride Safe
Bike-Doc
Sep 29, 2010 | Yamaha TRX 850 Motorcycles
-turns over but won't start -changed fuel filter
Check your battery as it supplies juice for the coil. Then check your coil or coilpak and the crankshaft sensor. The bad spark may be an underlying reason for how the truck has been running.
Do you know if the fuelpump is working? The Inertia sensor may have tripped while you changed regulators. You may need to reset the button on it to connect the fuelpump.
Jun 13, 2010 | 1992 Ford F150 SuperCab
NI have a HP Design Jet 110plus nr after put the roll hi start to take the paper roll and take out the all roll witout control. Im chaged the OOPS sensor but is same problem can you help me to solve this...
Im chaged the OOPS sensor but is same problem can you help me to solve this problem
Oct 05, 2009 | HP Designjet 110plus nr InkJet Printer
Hobart vertical mixer/cutter
IS THE OLD DRUMP SWICH IS BURN CLEANED OR CHAGE IT. GOOD LUCK.
Apr 29, 2008 | Food Mixers
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
597 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
