Question about Tappan TGF363 Gas Kitchen Range
Caloric Gas Range Model #355 19 years old. Is there a replacement ignitor available to replace the old one?
    President:
  • 1,015 Answers
Being that your range is 19 years old it might be a bit difficult to find the correct igniter but not impossible. The model number that you gave is not giving any good results. You can go here http://www.repairclinic.com/Caloric-Range-Stove-Oven-Parts?s=b74a13c249 and look at these igniters to compare with the one on your range. You might get lucky and one of these could be a replacement that will work. Most local range parts suppliers are very helpful on locating hard to find parts but you may need to remove the igniter and bring it in so they can match it up in their catalog. You might also be able to find the correct igniter if you use the part number on the ceramic igniter housing to do a parts search with. Most 20 year old ranges use a standard "flat style" hot surface igniter but there are different OHM ratings for some igniters and this rating is important for you to match up correctly with your current igniter OHM rating or you could damage the gas control valve and/or the new igniter.
Posted on May 12, 2010
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
On my Caloric gas stove Model RSK 3700 UWW, a control knob has broken off leaving about half of its stem (or tongue) tightly lodged in the stove's female control- knob socket. How can I extract this broken...
Unfortunately you can't remove or replace these buttons, no parts seem to be available anymore. Keep a match stick handy to stick in the hole and press the leftover bit.
May 09, 2010 | Jenn-Air JGR8855BDS Gas Kitchen Range
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Nov 22, 2009 | Ovens
Caloric oven does not completely light
i would replace the ignitor, although its glowing its not glowing strong enough to allow gas to release, simple repair, part numbr 31939701
Nov 22, 2008 | Kitchen Ranges
Tappan TGF363 Gas Kitchen Range Logo
422 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
