Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelite Super XL running very hot. Is this the carburator?
How can I solve the above problem?
    Brigadier General:
  • 4,088 Answers
Hot running saws are either in need of cleaning the engine and inner case of accumulated sawdust and dirt with compressed air, or the engine is running lean which will result in severe engine damage if allowed to continue. Check the air cleaner, fuel filter, and muffler for any plugging. Check the fuel lines for decay of any kind. Make sure the chain is being properly lubricated and sharpened. Check the carburetor fasteners for tightness including those mounting it to the engine. Remove the spark plug and look for a light to medium tan color on the inner insulator. If burning white, it is not getting enough fuel. Have the two jet screws been adjusted? If so, turn both screws to CW stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is 4-stroking at speed, but immediately 2-strokes when cutting. This produces best power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning , but the engine continues to run. Check chain oiling by holding the bar tip near a piece of cardboard and run the engine fast for couple of moments--the chain should throw off a thin line of oil. Hope some of this helps!
Posted on May 11, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
How old is my homelite chainsaw xl-12 serial number 2621590
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/a17d735d551f0f1e88256b78005f6a7b
Dec 01, 2014 | Homelite Xl 12,super Xl 12, Xl 15...
18hp ohv cuts out after it gets warm or hot like it is running out of gas
I have a 12.5 hp Briggs & Stratton on a Murray that did that. The carburator is right above the muffler and when I replaced the muffler, I didn't put the heat shield between the muffler and carburator back on. The added heat from the muffler was vaporizing the gas in the carburator where the engine would no longer run once it got hot. Replacing my heat shield and putting a longer pipe on the muffler to get it away from the carburator solved my problem.
Aug 05, 2013 | Craftsman Garden
I am looking for points,condenser,and module for a Homelite super XL Auto model ao21361721. Can anyone help me?????
cleaning the points should help them and replace the condenser that you should be able to match up or see if a coil from a new saw with electronic ignition and replace it did on my old still
Jul 03, 2012 | Garden
HAVE OLD HOMELITE SUPER XL AUTOMATIC NEED ON OFF SWITCH AND MAGNETO , WE HAVE NO SPARK AND HAVE DONE ALL THE OTHER THINGS . SER. NO 3G2550042 , THE NUMBER ABOVE THIS ONE IS , UT NO 10045-C
Is it this one? She has points.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
You may find parts for this grand old Lady here:
http://www.acresinternet.com/cscc.nsf/673d78ec01557aea88256b00005457e6/53fd90eee11e3fe8882572a300167f51?OpenDocument
Last chance try here (parts and guidance):
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This is an international collection of chainsaw enthusiasts with a few 2-cycle mechanics and saw retailers thrown in. They are a good bunch and I am certain someone can help.
I did not see any Homelite (most makers have one) thread but did find this:
http://www.arboristsite.com/showthread.php?t=120583&highlight=xl+super
Be kind to her. HTH
Lou
Jan 18, 2010 | Homelite Garden
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Jul 01, 2009 | Homelite Garden
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
399 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
