Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
I have the Verizon fios with the actiontek wireless router. I would like to set up the access point Linksys wap54g.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 15 Answers
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Posted on Mar 29, 2008
SOURCE:
Slower wireless speeds
Sorry to see you leave FiOS.
Without knowing how your EOC-2611s connect to your network, I can only speculate. But...assuming your 2611 plugs into the Comcast router... Check the Ethernet port status. It should be 100Mbps Full (Duplex). If it auto-negotiated to half duplex, that would explain your throughput issues.
Mar 30, 2014 | EnGenius EOC-2611 - Wireless Access Point...
Trying to install tp link w8980 on to plusnet fibre broadband
It's an ADSL router. Look at actiontek for fibre routers
Mar 24, 2014 | Computers & Internet
I want to use my Linksys WRT54G as a bridge going thru Verizon FIOS 9100EM. What settings needs to be changed on the 9100?
You really don't need to change anything on the 9100 but with the router yes. And setting up the Linksys router depends on how the 9100 was configured. Just let me know if you still need more help.
Dec 22, 2010 | Linksys Wireless-G WRT54GS Router...
Am using verizon fios wireless router 9100em but would like to add my linksys wrt54g for all wireless functions. Both routers use 192.168.1.1 to access router menus I can access the verizon but can't get...
You will need to change the dafault ip of one of the device.
Connect using a calbe lan first browse the ip 192.168.1.1
then change one of the device 192.168.1.2
Then set one as (ap repeater) access point router..
ok try this
Jun 30, 2010 | Linksys Wireless-G WRT54GS Router...
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
USB port on Actiontec for shared printer?
There is supposedly a firmware upgrade available that extends the functions of the usb port so the short answer is "maybe"
My best suggestion is to check out the actiontek web site. Also you should try access the setting page (http://192.168.1.1) and see what options are available within the router itself for USB
http://support.actiontec.com/doc_files/MI424WR_Rev._ACD_User_Manual_4.0.16.1.56.0.10.11.3_v6.pdf
Is the user manual
Aug 07, 2009 | Actiontec GT701WG Router (actiongt701wg)
Actiontec gt704wg antenna broken
yes, and here is the answer from the actiontek website
Is the antenna on the Actiontec Wireless Router and Gateway replaceable or upgrade-able?
Yes, the antenna can be removed and replaced or upgraded. The connection method is, Reverse Polarity Sub-Miniture Adapter (RP-SMA), is readily available at most computer or electronics stores.
Mar 20, 2009 | Actiontec GT704WG Wireless Router...
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Home Network issues
> you need to configure your wireless printer so that all computers will be able to detect it,your ISP or printer manufacturer will be able to configure that for you
Jun 30, 2008 | Actiontec GT704WG Wireless Router...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
434 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
