Question about LG enV3 VX9200 Cell Phone
Phone shutting off for no reason - LG enV3 VX9200 Cell Phone
    Problem Solver:
  • 7 Answers
Could be caused by an improperly seated battery.
Posted on May 14, 2010
Phone constantly shuts off even with full charge, & no obvious reason, how to determine cause?
Your problem can be a number of things like a bad battery, phone virus or defective phone. The first thing i would try is a soft reset and if that doesnt work id try a hard reset wich will return the divice to a factory state. WARNING a hard rest will erase everything so make sure to backup any saved data and remove memory card.
If those methods dont work then simply have your phone replaced through insurance that is provided to you through your service provider.
Jan 09, 2015 | Cell Phones
Tip
How to prevent samsung e2121b/e2120 from blinking and auto off problem?
hi,<br />samsung have produced a bad quality of phone model and it is e2121b and e2120 ,one of the common problem in this phone model is blinking for for a long time and auto shut off..the reason for that is the weak flash IC ( a small component in the phone in which the program is in it ) ...so how to prevent the phone from blinking and auto shut off?<br /> here is how ..<br /><br />1.prevent the battery to be totally drain ,because when it is drain it will start to automatic shut off ..<br />2.dont change your sim card or micro sd everytime <br />3.dont turn OFF the phone in the ON button ,just REMOVED the battery pack to turn on <br />4. and prevent the phone form dropping because once the flash IC is in defect status ,your phone start to blink and it will automatically shut down...<br /><br />i hope it will help you ,thanks for trusting fixya<br />
on Feb 12, 2011 | Cell Phones
My samsung transform ultra shuts down for no reason.. replaced battery. Even replaced phone.. new one does it too. I won't even be using it when it jus shuts off.. why? How can I fix it?
Could it be the screen saver is activating, blanking the screen, so that it reduces battery consumption? Try going into your phone settings and adjust the screen saver.
Nov 03, 2013 | Cell Phones
My motorola i1 (provided by boost/nextel) phone keeps shutting off & turning back on on its own. I have never dropped my phone nor got it wet. My battery is fully charged & it only shuts off &...
Try get another battery, it could be that the present battery you are using is malfunctioning, it could be bad and that could be the reason why it is shutting off and on, first, replace the battery to check the performance.
Jul 28, 2011 | Motorola Mobility i1 Smartphone
Hi. When i connect the USB cable the PC studio starts however it does not read my phone and after a minute it shuts down automatically. Pls help as not able to sync data with PC.
hi :) that have a reason of the pro. have your water damage before ?? maybe the port was dirty inside,make phone shut down. try send for technician have a check or servis.
Jul 06, 2010 | Samsung SGH-D900 Cellular Phone
My phone randomly shuts off
The reason your phone randomly shuts off is because it is having a minor software problem.
To fix this, all you have to do is to get the appropriate cable and software, then flash the phone.
Another fault that most likely be the irregularity of the phone is that the battery might be failing.
To fix this, all you have to do is to secure that the battery is well packed.
Make sure you do not have too many files on your phone, because it also could constitute to making the phone go off randomly.
Take care
Jun 22, 2010 | LG Vu CU920 Cellular Phone
Nokia 3555b shuts off for no reason
CAUSE:The Nokia's problem of shutting off is a design flaw.The tension in the spring at the positive contact is too low to keep the battery in contact with the negative pole.
SOLUTION:Just  wedge a small piece of paper between the actual phone and the positive side of the battery(not between the contact) .This will prevent the battery from shifting away from the negative pole which causes the phone to shut off...
Hope this helps.
May 18, 2009 | Nokia 3555 Cellular Phone
SOS!
replace the battery.
Jun 29, 2008 | LG CHOCOLATE VX8500 Cellular Phone
My 6030 has suddenly shut down!
it shutted down because (maybe)
of the folowing reasons:
1.) Error
2.) You have overloaded it,
3.) Full Memory.
try removing the battery (5 mins)
the put it back again.
then press on..
if it wont want to start.
charge your cellphone.
then try pressing the on button
Nov 02, 2007 | Nokia 6030 Cellular Phone
LG enV3 VX9200 Cell Phone Logo
155 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
