Question about GE 168997 Deep Fryer
I have 2 of these at home that have only been used a few times that will not heat up. There are no signs that they are getting power (no led). Any suggestions?
  • 4,059 Answers
There is a safety switch that has to be made when the heating element is in place. Look for a small button it should contact. Hold the button in and see if it will work. Be careful of the elements getting hot when you push the switch in.
Posted on May 11, 2010
Where can I get the best outdoor led signs for my business? Can you suggest me one of the reliable and best one?
You can get the best Outdoor LED Signs on "Digital Signs Direct USA". It offers a full range of outdoor LED signs including monochrome, tri-color, and full color along with sizes ranging from a few inches up to 20? X 40?.
The key features are:-
Powerful yet simple
Increase brand awareness
Customization capabilities
People take notice
Part of everyday life
Vibrant colors
So, this one will be the perfect option for you.
Nov 21, 2016 | Custom LED 10 Pattern Electronic LED...
Samsung has standby light, it blinks tone sounds no green light. Replaced t-con, power supply and control boards.
Hi Patrick,
have a close look at your LVDS cable and screen ribbons for signs of failure or heat damage, and you could try to pull a picture from an AV output in various formats to see if it's the screen itself is failing in some way,
regards
George
Jun 29, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Dell E173FP power led orange/flashing failure returns
First, you can get the service manual here: http://elektrotanya.com/
If the transistors failed again, yes the 0.22uf (part of tuned circuits for the inverter transformer oscillator circuits) changed value, the frequency will be off and causes over heat on the transistors due to too much current draw, You can also have bad inverter transformer, you can check the DC Ohm value but if it has one short turn, it will not show up on DC Ohm test, you have to use ringer testing (I use SENCORE LC75).
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Dell E173FP 17" LCD Monitor
Faulty LED in computer monitor power-switch
Check the power supply section to see if you do have 5v and 12v, also look for bad caps, see examples here on failed monitors because of bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 13, 2010 | Computers & Internet
Neon sign lights up inconsistently
If you are a trained person that knows how to measure electricity and switches, I would use a multimeter with the power off, and check the switch. Other than that it actually sounds like your ballast(transformer) is going out. They can be picked up pretty cheap at Lowes or Home depot. Good luck.
May 21, 2017 | Neon GREEN PC POWER SUPPLY KIT Power...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Asko Washer
I have a 12505 also. It is a 220VAC unit. There are two fuses that are intended to be accessible from the rear. On our unit, these blow every few years and need to be replaced. The unit shows no signs of life when they go. The fuse holders tend to disintegrate from the heat, so I have had to replace these multiple times also.
Nov 20, 2007 | Washing Machines
Works for a few minutes then shuts down
You both have a collection of dry solder joints and or bad capacitors. Check for any sign of buldging capacitors on the power supply board and replace as needed with the exact same values.
The dry joints in the solder are normally around the larger items on the board like transformers etc and places that alot of heat builds up. Check the regulators and other area's near there, and also check areas that sit above them when the monitor is in normal operating mode..hot air rises..too bad electrical engineers work on flat screens =)
Good luck to you both.
Apr 27, 2007 | Dell 1503FP 15" LCD Monitor
GE 168997 Deep Fryer Logo
353 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Audie Bogus
Audie Bogus
Level 1 Expert
Jay Finke
Jay Finke
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
