My laptop picture has suddenly increased in size beyond size of screen. How may I reduce it back to fit screen?
  • 4,281 Answers
For that make sure that graphic driver installed so you can change screen resolution.
For that go to start menu->control panel->display property ->Display property
Then go to settings change screen resolution to 1024*768 then apply and ok.
if you are not able to change screen resolution you need to reinstall graphic driver after uninstalling old.
for that right click on my computer icon then click on property then hardware->device manager then uninstall display adapter driver.
Then go to control panel->add remove programs and uninstall graphic driver from there.
Then reinstall graphic driver.
You need to change screen resolution to 1024*768 for fix this issue.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 11, 2010
After fitting youview box I now have reduced picture size on freeview how do I correct this ??
Check the zoom option on your controller, it could be that you might need to increase the size or "fit the picture" which should correct the problem.
Oct 10, 2014 | Televison & Video
How do i reduce the size of the images on my screen
Increase the resolution and the images will shrink down to fit appropriately in the new size screen.
Oct 05, 2014 | Nokia Lumia 1520 Red Factory Unlocked...
I want to reduce the type size on my laptop.
Right click on desktop screen, click personalize, the click adjust font size in the task..
Jul 19, 2013 | Cameras
I've lost the symbol to increase and decrease the size of what I have on my screen. How do I get it back THank you
add the status tool bar
you can also use Ctrl and - to reduce and Ctrl and + to increase size
Sep 19, 2011 | Computers & Internet
While playing a game the screen suddenly reverted back to the home page but reduced in size and with no cursor. I have tried turning it off and even removing the battery but just get the same reduced size...
In most cases this problem comes up by Antivirus program. It checkes running files. To identify the problem try disale antivirus program temporary, start your game and see what happens.
Mar 27, 2011 | Dell Vostro 3500 Laptop
The picture does not fit the entire screen size of the television
Possible that the power supply is faulty as a low +B- main power can result in the picture reducing in the screen. Also if there is fault in the convergence section, failure of the drivers, failure of the capacitors, it is possible that the size can reduce.
Feb 04, 2011 | Televison & Video
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Picture on Telefunken 72 cm TV expands beyond screen size
Your screen somehow got switched to theatre/cinema mode. There is a setting on the remote that attributes to aspect ratio. Sometimes it is called "ASPECT". Look for it, and press it until your original screen aspect shows.
Dec 15, 2008 | Apex Digital PF2020 20" TV
Picture and text extend beyond screen
Your tv needs to be put into service mode with the original Sony remote control and then set the vertical\horizontal size parameter to the correct values and then burn the new settings to memory
Google " sony tv service mode " and you should find the procedure. Good Luck! Write back if you have problems.
barneyluc
Oct 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
