Question about Electrolux ICON Designer E30SO75ESS Oven
Error: F 10
Electrolux range Model: EW3LGF6FGFF Serial: VF94557061. am getting F10 & unit beeps
  • 269 Answers
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
Posted on May 12, 2010
Electrolux oven (model#EW30IS6CJSB, serial#NF21223301) top element won't turn off.
It would not be element bc it only works when supplied voltage. And obviously it works when supplied voltage. Whatever is sending voltage to the top element that shouldn't be is the issue. Such as control board
Sep 25, 2016 | Electrolux Ovens
How do I stop an Electrolux double oven displaying a code F10 from beeping.
To cancel the F10 error, you need to unplug the oven or shut it off at the circuit breaker. Usually this error means that the oven is detecting a runaway temperature. Either the RTD (resistance temperature detector) sensor probe, the electronic oven (EOC) or the wiring is faulty.
You can check which one is bad by testing the resistance. The RTD sensor is on the back wall of the oven near the top of the cavity. It's somewhat easier to check the wire at the EOC. Unplug the connector and measure the resistance between the two wires. The resistance should be about 1100 Ohms in a room temperature environment. If you get the incorrect resistance, remove the sensor from the oven and check the resistance at the sensor. If you get the same faulty reading at the sensor and at the EOC, the sensor is probably bad. If the resistance is 1100 Ohms at the sensor, the wiring is bad. If the resistance is correct at all points, the EOC needs to be replaced.
Please add a comment with your oven's model number. I will try to find a source with the correct parts. I hope this helps.
Sep 20, 2015 | Electrolux 30" Built-In Double Electric...
Why kenmore oven code f-10 comes on when bake or broil is on
I would first pull your range out from the wall, unplug your range, then take off the back access panel and ohm your oven sensor.
It should ohm out at 1100 ohms at room temperature.
If that checks good, then your control board is the problem.
Here's the oven sensor probe for your model:
Part#316217001show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
yNjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Here's your control board:
Part#316418208show?id=yo6223wzsty&bids=122738.582384825&type=10&subid=
0NjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Aug 20, 2014 | Ovens
Frigidaire beeping with F10 signal
sounds like you need to get all food out and switch it off and leave the doors open and leave it for two days with the doors open ok then afther you have left it swich back on with doors closed do not open doors for 24 hours swicth on ok then it should be ok if not then its lack of gas
Oct 15, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Range beeps every few minutes
Typically this means the cycle is completed or there is an error detected. Reset the unit at the household circuit breaker fora bout 10 minutes, then retry the unit. Let me know if this happens again. Also let me know if you see any alpha-numeric error codes.
Aug 31, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Hello- my oven is a kenmore model 790.94224409 and I keeps getting overly hot and shutting off 10 minutes into baking. It beeps and i get a F10 error type code. Every time i open the range door, it...
Sorry to read about your problem, I hope this helps you out.
you have a defective temp sensor
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore Ovens
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Electrolux ICON  Designer E30SO75ESS Oven Logo
1,105 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
