Question about Kitchen Ranges
I have a rinnai that is clicking and not working at all. The controller is blank (no codes)
  • Jeffery Crow May 18, 2010
    This unit as it turns out has a faulty water flow servo & sensor, it has been replaced $142.00 part only through Rinnai. The controller is back up and running and no more clicking (the test of this was a manual overide, by undoing the flat four blade connector and turning the unit back on) so far so good.
  • 19,396 Answers
Hi.
The clicking noise is usually caused by a faulty control board . If the model has a relay board (power board), this must also be tested.
All you can do as an user is tripping the circuit breaker to disconnect power for a couple of minutes. This will drain power from control circuits and can fix a jammed control board.
If that does not work, then the control circuit must be replaced or repaired at component level.
Posted on May 11, 2010
Rinnai code 99
i am not an expert. this is how i fixed my rinnai code 99. my rinnai 100 4f would run for few seconds then the red light would continue to flash. code 99 would come up.i took the unit out of service. i notice that the fresh air hose had two very small hoses located on it's elbow had been switched around when i took it to be serviced. the unit worked well. how ever. i changed my mind when i realized the service was not need. anyway the two small hoses on the elbow one office is larger than the other and they must be put on the correct one,i switched them around the unit flamed up. and now i have sweet heat again.no code 99.
Dec 17, 2016 | Rinnai Heating & Cooling
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
How to fix gas heater Rinnai RCE-229H?
get a gas fitter in to fix the problem as gas is less forgiving than electricity
Jul 19, 2015 | Rinnai Heating & Cooling
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
I have a Rinnai Model 2532 with an MC-45-4US and BC-45-4US control units. I finished another bathroom and want to add a controller, but have been told that a compatible BSC-45-4US is no longer made. Is...
Sorry Ken I worked for Rinnai Australia as a service manager so treat my advice with a little cuation but you should find the basic universal controller should work fine. The code over here is a MC-91 Q2A. It will MC-91 sometihing for over there (I'm guessing from the codes you use you are across the pacific!). You can wire this unit either back to the heater or to wiring from another controller, just match the colours and link them in. Power off the heater first but it is all low voltage.
May 26, 2011 | Rinnai Digital Remote Water Heater Control...
Rinnai Gas heaterFailure code comes up 53 which indicates sparker failure. Turn unit off and it works normally for a while. Error code says cal for service. What is normally involved in fixing this problem...
I would replace the cord between the ignition module and the control board. It is a ribbon style of harness and only costs a few dollars from Rinnai direct. It is something that can be done by a mechanical inclined person in about 20 minutes. Contact Rinnai parts (usa) at 800-621-9419. Give them your exact model number and ask them for the harness between the two mentioned components. Good luck!
May 04, 2011 | Heating & Cooling
My Rinnai infinity 20 water heating is not lighting
Just joined fixya and am a Rinnai service manager in Australia. Is this still an issue?
Apr 11, 2010 | Rinnai Digital Remote Water Heater Control...
Rinnai 1004fa
page 35 of the following: http://www.rinnai.us/Rinnai.aspx/FileLibrary.aspx/DealerResources.aspx/DocumentsLibrary.aspx/WallFurnacesDirectVentMainHeatSource.aspx/RHFE1004FA.aspx/GeneralInformation.aspx/456RHFE1004FAManual32003.pdf.aspx hope this helps :)
Dec 24, 2006 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
