Question about Solis Maestro G385 Electric Burr Grinder
My machine grinds perfectly, but the hand dial came off and when reinserted will not turn the timing mechanism. Since it is stuck on, I have to keep the grinder unplugged and plug it in again when I want to grind coffee. Is part replacement available without sending in the machine for repair?
  • 1,089 Answers
Hi
Try Baratza 877-701-2021
Posted on May 11, 2010
My model no.158. 1792184 is sewing backward how can i make it sew forward
Have you cleaned and oiled the machine lately? If it's mechanical (NOT computerized), it needs regular oiling to keep it operating. Could be that the reverse mechanism is stuck. Can try directing hot air from a handheld hairdryer into the internal works to see if it loosens. Open the top lid and also the area where the bobbin resides. Hand rotate the handwheel and using ONLY fresh good quality sewing machine oil, apply 1-2 drops of oil every place that metal rubs on metal (NOT plastic, rubber, leather, or belts!). Hand rotate the wheel until the oil has had a chance to work in and then try running the machine with the motor. Try to also apply a couple drops of oil to the mechanisms operated with dials and levers to get them loosened.
Nov 27, 2015 | Sewing Machines
The pattern selector dial is completely stuck!
If your machine is mechanical (NOT computerized), it most likely needs a thorough cleaning and oiling with good quality sewing machine oil. The old oil has solidified and preventing the parts from moving.
TRY THIS ONLY IF YOUR MACHINE IS MECHANICAL:
If the selector levers are sticky/stuck or the handwheel is stiff or does not turn, about 98% of the time the machine needs oil.
Mechanical machines need to be cleaned and oiled regularly just like your car. If the machine sets in storage for a while or is used often but not oiled or cleaned regularly, the oil that exists in the machine will eventually thicken and acts like glue. (Sometimes you can see a dirty-looking dark gold or brownish goop which is usually old oil.) Then your machine is frozen.
First, open the top and bottom of the machine and sweep out any dust, dirt, lint, or stray threads.
Now, oil your machine (consult your owner's manual maintenance section). There are usually quite a few oil holes (both in the top and bottom of a mechanical) that require periodic oiling (see your machine Manual for a diagram). If a metal part is frozen, buy a bottle of liquid Tri-Flow Synthentic Oil (from the hardware store) and put one or two drops in all the spots shown in the manual. (DO NOT oil rubber parts, the plastic gears, the belts, or the metal CAMs!!! NEVER use 3-in-1 oil, cooking oil, WD-40, or oil from your grandma's sewing box. And do not put more than one or two drops of oil at a time as over-oiling will also damage your machine.) It also helps to slowly hand rotate the handwheel and, while watching things that move, apply 1-2 drops of oil every place that metal rubs against metal. Do this also with the selectors and dials.
Then, using your hand-held hair dryer, direct hot air into the internal part of the machine (top and bottom). The metal may become hot to the touch. Then try to gently move the handwheel and the selector levers. Repeat. Let it set overnight. Then test again the next day, and repeat the process if needed.
To maintain your machine, a good recommendation is to oil every time the bobbin thread is changed, every 8 hours of constant sewing, or every six months if the machine is not in use. Use a good quality oil, ie Bernina oil for "mechanical" machines or similar. When oiling, also be sure to brush out the dust and lint (especially around the feed dogs and bobbin works).
If the oil in your tube looks dark colored, throw it out and get some new. I've run across some old sewing machine oil in the can that looked like dark honey and stunk to high heaven. Get rid of it!
Treat your machine well and it will serve you well for many years.
Oct 07, 2015 | Sewing Machines
The reverse button and the stitch length dial
Do NOT try this on a computerized machine!!!
If the button and dial are sticky/stuck on a mechanical sewing machine, frequently you can loosen them by applying liquid Tri-Flow Synthetic Oil (usually available at a hardware store) ONE drop at a time to the internal moving parts of the machine (focus on the mechanics for the dial and the button). Gently rock the two selectors to get the oil worked in. You can also direct hot air from a handheld hair dryer toward the selector mechanisms to loosen the old oil. You may have to repeat both processes several times if they are really frozen. (Sometimes it may take repeating the process several days to get them loosened!)
Once you get them moving again, you should consult your owner's manual for cleaning and oiling instructions and follow up as directed. You can use Tri-Flow or a good quality sewing machine oil (NOT 3-in-1, WD-40, or cooking oil!). Many older mechanicals are frozen because they have not been regularly maintained. Set a schedule to regularly clean and oil your machine, such as every 30-40 hours of continuous sewing, every time your bobbin thread runs out, every 6 months if not in consistant use. Doing so will help keep your machine operating.
Jun 13, 2015 | Sewing Machines
Any suggestions on how to remove the grinder?
most likely a coffee bean is stuck in the grinding mechanism.....just keep wiggling and pulling, and try turning back and forth.
Sep 11, 2014 | Cuisinart Coffee Makers & Espresso...
Bernina 831
The buttonhole dial (middle dial with the two buttonhole bars indicator in the center of the dial) is positioned somewhere past the top center mark so as to lock the mechanism up.
Also, due to oil varnishes that have accumulated on the buttonhole bearing plate mechanism, the buttonhole knob/dial will not rotate easily clockwise to put the mechanisms back to normal. This will require a repair to remove these varnishes.
Caution: (do not turn or force the buttonhole knob/dial counter clockwise). You can also break the buttonhole dial by forcing.
Machines of this age are now varnishing and need to be solvent cleaned to remove the solidifying residues that cause binding in the machines mechanisms.
Often, due to inexperience, technicians have used aerosol sprays that are not intended for lubrication, but rather as corrosion inhibitors, thus adding and seriously complicating the oxidation process of oils. Certain and most common spray lubricants found in hardware and even grocery stores are accidentally sold a lubricants. Once the varnishes form in combination on and in the extraordinary high precision of Bernina machines mechanisms, sticking is very common. The repair requires some very striong solvents to loosen and remove the varnishes so great care must be taken for personal safety as well as the prevention of damage to the machine.
The Bernina 1982 technical bulletin No.1 forbade the use of aerosol sprays due to varnishing problems.
Aug 01, 2014 | Bernina Sewing Machines
I am sewing on outdoor canvas fabric and my thread keeps breaking. What should ALL dials be set at for this type of fabric?
What size needle are you using? You need a heavy duty, probably a #16 or #18. Some machines are not made to do it. The old flat beds were tough enough and the newer machines have a tougher time of it. If, it still does not work, try turning your handwheel towards you by hand for each stitch, I know, what a pain but it will do it if you go that slow. I have been sewing for 50+ years and have done it. Good luck, be patient, keep cool.
Apr 18, 2011 | Brother XL-3510 Mechanical Sewing Machine
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
Ground coffee does not come out
Try this, unplug grinder, vac out all beans, then turn grinder towards fine until you cannot turn the big nut in the center of the burr chamber with your fingers. Now turn adjuster towards coarse until you can barely move the middle nut(you should hear and feel the burs touching) now if you look around the edges of the adjustment ring you will see notches, pick a spot any spot just remember where you started, then turn 14 notches towards coarse, your grind should be almost perfect.
Jul 03, 2010 | Mazzer Grinder-doser MINI
Hand wheel is stuck
hi there,
well,stuck up hand wheel, is due to mechanical obstruction inside machine,bushing on shafting need to oil,and on handwheel bushing near clutch there is oil port there. since hand wheel are connected to cam shaft with set of gears and pulley is coupled to motor pulley,and other linkage under bobbins,shuttle race etc,broken gears are most common causes of stuck up handwheel,we can consider also the brush carbon,when worn out and damage the rotor commutator brush.if you can open the cover of motor below side of handwheel,you can see the pulley and motor assembly.also on top of machine there an opening to see the top gear assembly,this should be done by service technician.try to bring to nearest service center if still under warranty claim this for lesser maintenance cost.have a nice day,don't forget to rate me.thank's.
Apr 20, 2009 | Sewing Machines
Stops brewing before all water empties from reservoir
I went to Hamilton Beach site and read the troubleshooting. I followed there cleaning instructions and reduced grind time on my coffee and the machine is working perfectly again. I stressed over this problem for a long time before following their operating instructions. Have had the machine for over two years now and it's back to working perfectly. i.e. Run a pint of white vinegar through it. Wait 30 minutes and run another full vat of water....wait again and run another full vat of water. If you're grinding your own coffee, you may be grinding it too fine. Otherwise Hamilton Beach recommends the kind of coffee to use. Also the problem maybe too dense of a filter. This is all info I got on the H. Beach troubleshooting site. Good Luck !!! Mine is back to working great !
Jul 24, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Solis Maestro G385 Electric Burr Grinder Logo
142 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
