Question about Hotpoint RLA30 Compact Refrigerator
Hotpoint RLA30s Freezing!
Hi All,
I have a Hotpoint RLA30S Fridge that is freezing all of the food inside. This started after moving it from the kitchen to living room when I was redoing the kitchen.
I have just fitted a new thermostat sourced from Hotpoint but the simptoms are the same. Even at the warmest setting the compressor does not seem to turn off.
Does anyone know if there is another part that could have gone faulty or is there something I should have done when I fitted the new thermostat?
Thanks in advance all,
Rich.
  • 1 more comment
  • richard_wags May 11, 2010
    Thanks for the reply, but, how do I check the relay? Do I check for continuity between certain pins?
  • richard_wags May 13, 2010
    can someone give me advice on why my fridge is freezing? Thermastat has been changed. someone suggested the PCT relay but I do not know how to check it or even access it. Thank you.
    Does anyone have the Service manual for the Hotpoint RLA30s so I can check the thermostat is working please. It would be handing to have the wiring diagram and see construction of the parts. It can be sent to richard.wagstaff@gmail.com. thanks in advance.
    Guru:
  • 1,049 Answers
The FREEZER determines the coldness in the refrigerator as well as the refrigerator itself. Even those that have a separate thermostats. This is because the units still share a single compressor. I would check your temperature control before trouble shooting other problems because it may just be set too high. Also make sure that you have not packed the bottom or top of the fridge too full. Bad air circulation will cause the thermostat to misread the temperature. Similarly, make sure that the seals around your door are good.
If all else fails, check that the fridge can drain properly. This doesn't usually cause freezing directly, but can cause ice to build up around fresh produce.
  • Shut down the fridge, let it drain out
  • In the back of the freezer, locate the small drain hole. Make sure this drain hole is clear. Remove any food particles if necessary, and pour small amounts of hot water down it until the water flows freely. You should be able to hear it drain.
Posted on May 13, 2010
  • 1 more comment
  • NA NA
    NA NA May 13, 2010
    Thank you for the reply JackHeath. The fridge is just a fridge and not a fridgefreezer, not does it have a freezer compartment in it.
    Thanks for the link to the owners manual but I was after a service manual of some kind, one that gives the wirering details, dismantle/rebuild instructions and parts list. Do these exist?
  • NA NA
    NA NA May 13, 2010
    I find a lot of my manuals and stuff here, looks like they might have it somewhere in that list but it needs the full model number.
  • 2,973 Answers
You have done everything right. it seems that the new thermostat is faulty too. Send it back to HotPoint. Unless there is a short circuiting after the thermostat, ie, between the thermo and the compressor. These are the only two reasons that could have caused the problem.
  • 192 Answers
This does sound like a "small gas leak" that causes the fridge not to reach the full cold point of the thermostat. This is because the gas that has leaked out causes the fridge to get cold BUT never reach the cut off point of the thermostat. What follows is that the fridge eventualy now slowly warms up and ends up not getting cold (can take a week or 2). You will need to find the leak (very small) fix it and then re-gas the fridge.
Posted on May 11, 2010
  • richard_wags May 12, 2010
    Thanks for the reply joe_lishman but I'm not sure that makes sense to me, the fridge does not have a problem getting cold - its freezing. T'his sounds like the apposite to what you have suggested. The fridge gets colder and colder and freezes the food. I have fitted a new thermostat, someone has suggested the PCT relay? There is a module on the side of the compressor but I cannot see how to gget it off, nor can I see it as a part on Hotpoints spare parts list.
    President:
  • 2,468 Answers
Check the ptc overload relay it could have stuck and is supplying power to the compressor all the time even if the thermostat is off,its on the compressor body where the wires go to the compressor
    Thanks for the reply, but, how do I check the relay? I cannot see how to get the unit off the side of the compressor. I've takent he housing of which covers the power in and out and undone another screw but cann't remove anymore?
    I cann't see this part as a spare on the hotpoint website. could it be anything else?
  • adz648 Nov 20, 2010
    We're you able to sort the problem out as I have the same fault?
We have a Sharp R&L Fridge/Freezer - it is freezing everything in the fridge compartment - please could you advise whether we should move the dial to Min or to Max to make it warmer inside to prevent...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 05, 2011 | Sharp Refrigerators
I have a Hotpoint FFA74 fridge freezer and the freezer high temp button keeps switching on and everything in my fridge is freezing.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Hotpoint Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
Food in bottom compartment freezing food
you have the air flow regulator in the bottom of the fridge close to bottom compartment wide open experiment by closing it gradually till you have the desired result.
Sep 18, 2009 | GE Hotpoint Top-Freezer Refrigerator
Food freezing in Hotpoint refridgerator
Hello, Your problem is going to be with your cold control/Thermostat this can be located in the control console inside the refridgerator. This part needs to be replaced, the part number is WR9X10042 Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike
Jul 24, 2009 | Refrigerators
Food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Jan 25, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint Fridge freezing the food.
If you give me the model number I can find an exploded view, alternatively enter model number here to get the schematics.
Oct 26, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge is freezing food
no more than likely that your thermostat is faulty all f/freezers have 2 stats 1 to keep fridge cool and 1 to the freezer u will need to replace the 1 in the fridge m8
Aug 15, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RLA30 Compact Refrigerator Logo
484 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
