I have a kenwood TS-450s radio that has quit working on the 10, 11 and 12 meter bands. If you turn the radio on and it is on these bands you just get dashes on the display and no sound or transmit. But you can push the M/V button on the front of the radio and it will work for a minute or two. All the other bands work fine. Thanks Harvey
  • dirtboss Mar 29, 2008
    This did not help with my radio.This is a kenwood TS-450s ham radio. Need an answer that is correct for that amount of money.
    Thanks
    Harvey
    Genius:
  • 3,587 Answers
Hmmm...that's a little weird..perhaps that section of the tuner components is off adjustment? you a technical sort of down to the component guy?
Posted on Mar 28, 2008
  • Patrick Michaels
    Patrick Michaels Mar 28, 2008
    that link goes to a 570 which is similar, but not exact..
    Genius:
  • 3,422 Answers
HI,
Click HERE to download the user manual.I hope this will help you.
Please go through the troubleshooting steps in the manual.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Mar 29, 2008
    You can go for other expert's advice.You can deny our solution's and your question will be posted again.You don't need to pay for that.
SOURCE:
KENWOOD TS 450S WITH RX PROBLEM
If you are still seeing meter deflection in received signals, it sounds like something in the audio amplifier went south.
Apr 23, 2014 | Radio Communications
Kenwood ts-430s
where are you tx'ing, if its out of band it wont or maybe its got a bad final, is there any power, have you checked it on a dummy load
bad swr, out of band etc
Mar 18, 2014 | Kenwood TK-430 Two Way Radio Parts
Kenwood ts 450s
Have you tried downloading a PDF of the service manual? I found several sites with Google: "kenwood ts-450s service manual"
Jan 10, 2014 | Radio Communications
Kenwood ts 450s
Nice rig, what's the question?
Jul 27, 2013 | Kenwood Radio Communications
Front panel turns off
Have you performed a FULL reset on the TS-2000?
To perform a full reset:
With the power off press and hold down the A=B button and with the other hand turn on the TS-2000.
After that you will have to press the A=B one more time. The radio will reset itself,
and the display will show 14.000 MHz in the main band, and 144.000 MHz in the sub band.
Please let me know if it worked for you.
Tommy
KG4TDM @ arrl .net
Sep 12, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
TS-450S Noise Blanker, No 1 & No 2 neither has any effect on noise
The noise blanker settings on the TS-450S (and S/AT) are true noise blankers and should not be thought of as a DSP device or something that they are not, like a notch filter or IF shift and etc. They will do a fine job of eliminating ignition noise as well as eliminating the electric mixer or blender noise from the kitchen...... however they will not remove static crashes or quieten those atmospheric noises on 75 meters during summer time thunderstorm season activity.
Hope this helps!
Apr 15, 2009 | Radio Communications
Kenwood TS-450S won't load on new 20M dipole.
Surely you've checked connections, etc.----could balun have gone bad? Also are you using an external tuner? Lots of MFJ tuners will "screw up" once in a while. Open it up and inspect it
Dec 31, 2008 | Radio Communications
TS 2000 KENWOOD TRANCEIVER
I have the same problem with my TS2000 , in VHF I can heard small signals only if I turn on the PRE Amplifier ...
It start just few hours of use .
Jul 31, 2008 | Computers & Internet
Kenwood ts-450s - cannot tune and no ptt
This is usually due to a stuck or shorted ptt line. I have repaired a couple of these and it was the same component each time. The packet TX transistor Q65 shorted causing the radio to power up in TX inhibit mode. Transistor Q65 is located on the underside of the IF board under the ACC 2 connector. This switching transistor is used only for tx (pin 9 of acc 2) and no other circuits depend on it. It can be removed completely if you don't mind not having ptt on acc 2.
This seems to be a common problem lately, I hope this helps you.
Apr 26, 2008 | Radio Communications
220 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
