Question about Cruiser Accessories Classic Bicycle Bullet Light Chrome Lowrider Cruiser
My light doesn't work. I presume it needs a new bulb, I open up the bullet and there appears to be a space for what looks like a battery pack... what am I missing? Does it need a new bulb and battery?
Best just go and buys yourself a KNOG light- they are easy to put onto your bike and really reliable.
Posted on May 13, 2010
Dyson will not start
If the power cells are operational and it will not start; then either the motor is dysfunctional or something is jammed in the intake module. A conduction test with instrumentation can indicate if the motor is the problem, the power cells are not fully charged, or you have a short circuit. Check Fuses.
Feb 26, 2014 | Dyson DC44 Animal Digital Slim Cordless...
I have 3 landscape lights that were working but quit working in a system with about a dozen other lights that continue to work. I presumed the bulbs needed replacement but that didn't help. I verified...
My experience has shown that this is nearly always a connection and/or wire corrosion issue. Be certain that all connections are clean-if not clean with fine grit sandpaper or replace. Remember these devices are exposed to the weather on a continuous basis.
Nov 04, 2013 | Intermatic Malibu 300W Power Pack...
Describe your Malibu 121W Power Pack Transformer ML121RT Problem my unit just fryed itself as I had a underwater light hooked up to it. however it took 3 years for this to happen plus I think I had more...
Power pack wattage has to match bulb wattage, or it shortens life of power pack.
I don't know physics and electrical engineering enough to know why this happens.
Also when working on bulbs, manual says to unplug power pack so it doesn't burn up.
If bulb is under water that's fine, but wiring cannot be underwater where it shorts out, or suspect this action might also shorten life of power pack.
With receipt, power pack could still be under warranty.
Open following link for power pack resources, and links:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 23, 2011 | Intermatic Malibu 121W Power Pack...
2003 883 custom sportster has no rear running lights, but when I hit the turn signals, they flash. Also, the tail light quit working. I can mess with the bulb and get it going, but when I hit the brake,...
HI THE PROBLEM WITH YOUR REAR LIGHTS IS THAT YOU HAVE A BROKEN NEGATIVE WIRE FOR THE REAR LIGHT CLUSTER TO PROVE THIS, SIMPLY RUN A LENGTH OF CABLE FROM THE METAL CASING OF THE LIGHT CLUSTER AND GO DIRECT TO THE BATTERY NEGATIVE IF ALL THE LIGHTS THEN WORK THAT PROVES ALL THE FEED SIDE .MOST MOTOR BIKES HAVE BULLET CONNECTIONS YOU NEED TO TRACE THE WIRING FROM THE BACK OF BIKE TO THE FRONT UNDER THE SEAT TO THE FUSES IF YOU CAN,T FIND ANYTHING LOOSE OR BROKEN THEN I SUGGEST YOU MAKE A NEW NEGATIVE RETURN TO BATTERY NEGATIVE A PERMANANT ONE THIS SHOULD SOLVE THE PROBLEM. GOOD LUCK{ FROM AN AUTO ELECTRICIAN}
Aug 12, 2011 | 2003 Harley Davidson XL 883 R Sportster
Battery cannot be charged. you must use a Sony Ericsson battery
The message that flash on your screen is correct,you need to provide a new original pack battery,the reason why the message appears because your battery might be open voltage or to much voltage entering to your mobile and resulting to a damage case,look for the original battery,mostly class A battery pack is not suited to your phone cause it doesn't meet the voltage requirement and specification.
Hoping this method will help you,thank you for visiting fixya.
Jun 18, 2011 | Sony Ericsson Walkman® W995 Cell Phone
I just replaced a light (not bulb) in my Malibu low voltage lighting system with a new one and the new one didn't work. Now the rest of the lights past this point do not work, but the ones before this...
Working with the bulbs can cause other bulbs to go out.
Malibu suggests turn power pack off when replacing bulbs.
Also connections get loose and need to be re-attached.
Open following link for Intermatic/Malibu power pack resources.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
I just replace a light (not bulb) in my Malibu low voltage lighting system. That new light did not work and now all of the rest of the lights past this point no longer work. But the lights between this...
Upvote the help.
May 29, 2011 | Malibu Intermatic Inc. ML121RT Low...
I need the wiring diagram for lights in the living space. the lights in the living room don't work. the bulbs are new
Are you talking about a camper that is mounted in the truck bed? A truck doesn't have a living room. If your talking about the interior light check you dash board light dimmer control to make sure it hasn't been turned off.
May 15, 2011 | 1984 Ford F 350
Couple of problems
does the car run ok when running [or does it use more gas than usuall does it idle ok] noises coming from your intake that are loud is normally signs of an inlet valve burned . you say one brake light works the other doesn,t but the the brake light stays on all the time first of all you need to fix the brake light that is not working i presume when you say you checked the bulb on the light that is not working firstly is it the correct bulb and is it in properly as they are handed and even if it looks ok check it by replacing it with the bulb out of the other one you know that works if thats ok fine if it still doesn,t work your going to need to check that there is a live feed to it and a ground but needs this sorting first. for brake light to be on all the time it must have a live feed so the favourite is going to be a faulty brake light switch take the wires off this and see if the light goes out it should if not your going to have to check the wiring from the switch to the rear lights yates210456
Sep 28, 2008 | 1993 Nissan Altima
Laptop Sony Vaio
You might remove the battery pack and try it on AC only; it's possible that the battery pack has died while it was not being used or recharged. If it does work without the pack, you can choose to make a permanent 'desktop' unit of it or bite the bullet and buy a new battery pack. If you buy a new one, shop the price; it can vary at least 2:1.
Sep 17, 2008 | Computers & Internet
Cruiser Accessories Classic Bicycle Bullet Light Chrome Lowrider Cruiser Logo
77 people viewed this question
Top Cruiser Accessories Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cruiser Accessories Cycling Expert? Answer questions, earn points and help others
