I want to replace the control panel for my Phaser 7400. I have the new part ready to install. I need specific, step by step instructions that start with how to remove covers to replug your printer and turn it back on. :)
  • roberta712 May 11, 2010
    The part I'm referring to isn't one of the interior control boards. It's the outside LCD control panel.
    Thank you - this was just what I was looking for!
  • 19,396 Answers
Hi.
This printer has several control boards.
I am uploading the full service manual, so that you can follow the step by step instructions and help yourself with the pictures. The page will be ready in ten minutes.
Thanks for your patience.
Ginko
Posted on May 11, 2010
  • Ginko
    Ginko May 11, 2010
    Here the manual:
    http://www.megaupload.com/?d=ME4ZZGL0
    Here the control panel procedure:
    Control Panel
    1. Release the 2 hooks closest to the printer from underneath the Control Panel.
    2. Lift up on the part of the panel closest to the printer to remove the Control Panel
    faceplate.
    3. Remove 1 (metal, 6 mm) screw that secures the ribbon cable.
    4. Disconnect the ribbon cable from the Control Panel Board.
    5. Remove 4 (Black, plastic, 10 mm) screws to remove the Control Panel Hinges.
    6. Remove the Control Panel and Rear Cover.
    7. Release the mounting bracket by sliding it slightly downwards.
Phaser 7400 14: real time clock
According to my service manual, this error is occurring during the Power On Self-Test. While it is a "soft" error, it normally can only be resolved by replacing the Image Processor Board.
But wait! There's more!
Here may be a way to reset without the expensive replacement:
The most likely cause is that the Image Processor Board has not successfully loaded
its NVRAM contents (instructions) into RAM. All print engine operation halts, and
will only become ready when the Image Processor Board successfully boots.
1. Check for media or debris in the paper path.
2. Power cycle the printer.
3. Verifying Image Processor Board failure:
a. Power-off the printer, and remove the Image Processor Board.
b. Power-on the printer. Wait at least 5 minutes while the print engine
initializes. If there was a problem with the Image Processor Board, it will
now not affect the Engine Control Board.
c. If characters appear on the Control Panel display, the Engine Control Board
is functional and the problem is most likely with the Image Processor Board.
d. Turn off the printer and reseat the Image Processor Board and turn on the
printer to determine if seating was the problem.
e. Perform a PostScript NVRAM reset, see "Postscript NVRAM Reset" on
page 6-9.
f. Turn off the printer and systematically remove individual optional
components from the Image Processor Board to isolate a possible problem
component.
g. Replace the Image Processor Board.
I wish you luck with this repair.
Dec 07, 2014 | Xerox Phaser 7400/DX Laser Printer
The display does not work, it's just a blank screen
We have had that problem before what you have to do is replace the control panel. Part # 802K93860. You should check with xerox if the machine is under warranty and maybe they can ship you out a new control panel for free. It's worth a try. Anyways good luck.
Jan 16, 2010 | Xerox Phaser 7400/DXF Laser Printer
Phaser 7400 LCD is blank. How can that be fixed?
Once the LCD is gone blank that means you have to change the control panel. it's not difficult to change, all you have to do is remove the covers that are behind the the control panel. Once you have removed the white covers you can now unscrew the metal hinges. Then you have to insert a flat head in the small cracks behind the control panel that opens the control pane blue covers. Now you disconnect the data cable that connects from the control panel to the machine and that's it. Hope this helps
Nov 02, 2009 | Xerox Phaser 7400/DXF Laser Printer
Phaser 8560DN display Panel is blank
I got support from xerox. I need to get a replacement display panel for my printer. www.support.xerox.com
Oct 22, 2009 | Xerox Phaser 7400/DXF Laser Printer
Epson stylus cx 7400
Epson includes step-by-step instructions on changing the ink cartridges in the Printing Preferences menu:
Click the start button and open the Control Panel.
Right click Printers and select Printing Preferences.
Click the Maintenance tab.
You should see a button that says Ink Cartridge Replacement.
Just follow the instructions and it walks you through it.
Sep 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Xerox phaser 7400
There really isnt an easy way to do that.
The transfer belt assembly starts off with a fuse on it to blow immediatly on install, and a counter that is internal so that it will end of life and have to be replaced. It's really not a convience counter but an obsolence counter.
Mar 06, 2008 | Xerox Phaser 7750B Laser Printer
Power up Issues
I am suffering from the same problem and I called Xerox. The problem is your control panel and this is a known defect for this printer. My replacement os on its way. It appears that if you take off the control panel, you can find a bad soldier joint.
Aug 24, 2007 | Xerox Phaser 8550/DT Thermal Printer
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
