Question about Whirlpool Duet GHW9150P Front Load Washer
Can't find the Drain pump catchment on the whirlpool ghw9100w1
  • 5,911 Answers
The following link explains how to access and clean out the drain pump reservoir on a Whirlpool Duet:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and still experience problems (such as error codes), you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. Any error codes are generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 11, 2010
My Duet ghw9100w1 sometimes does not drain after a wash cycle. It will start beeping and give the f2 code. Sometimes it works fine. Other times you have to turn the unit off and turn the dial to rinse spin...
hi, brett you will need to test the pump with a multimeter it may a slight open circuit. with power off and unplug the machine. take the 2 wire off the pump. and set the meter to ohms this look like horse shoe symbol stick the meter probes either side of the metal contact on the pump. you see the meter working .it should have 0 ohms but you may about 4 to 6 oms this ok anythink higher the pump is faulty good luck hope it helps
regards
shaun
Nov 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you reset the washer it is stuck on 12 sec left needs to spin it has been giving a f 2 error laely
Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any obstructions.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine flashing F02
- Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any debris.
Nov 29, 2010 | Whirlpool Washing Machines
Stops with code F02
- Pull the suction boot off the drain pump, clean out any gookus.
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GETTING A F2 CODE AND THE MACHINE JUST BEEPS
F2:---Drain pump error. Clean out the drain pump catchment.
---------------- remove the bottom front panel and there is a white plastic catch basin with a removable-by-hand, large facing forward lid. Remove it
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation
Sep 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the f2 error code mean and how can I fix it?
A lot of times this error is associated with a unit that cannot drain properly. It can be caused by something in the pump or drain line, and the sensor which monitors output has an error because it thinks there is a blockage.
Your first tasks will be to clean out the drain pump catchment. Then remove the pull the suction boot off the pump itself and clean out anything there. Then you can blow thru the drain hose from the pump end to make sure nothing obstructed there. Lastly if you find nothing or it does not solve your error it is possible the pump needs to be replaced. Most of the time this is caused by something small such as an undergarment or sock in the pump line.
Hope this helps.
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting the f 02 notice can you help me fix it
This problem is usually caused by what we professional appliantologists call, "panties in the drain pump." 'Course, that's just generic talk for something ain't opos'd to be there. Your hit list:
Mar 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 message appearing on washer, what does that mean
Something clogging the pump or drain line. Clean out the drain pump catchment.
This is how to clean the drain pump catchment: Remove the bottom front panel to see a white plastic catch basin with a removable-by-hand, large facing forward lid (peanut butter container sized) Remove it and clean out.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer shows F2 and won't complete the cycle
- Clean out the drain pump catchment. Remove the bottom front panel and there is a white plastic catch basin with a large facing forward lid (peanut butter container sized). Remove it and Voila. Fairly easy fix-it job.
- Pull the suction boot off the drain pump, clean out any ****.
Dec 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F 2 code
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
353 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
