Question about Carrier Heating & Cooling
Unit does not power up no lights. checked to make sure there is power to unit checked cirut breaker. nothing any ideas
  • 82 Answers
Check internal fuse IF you are sure the unit is receiving power. The fuse will beinside the unit.
Posted on May 11, 2010
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
My microwave is not heating
Are you sure you have power at the outlet? If not check your circut breaker box. You may have a GFI circut. The GFI outlets are very sensitive. They have reset button and test button. If other "non GFI" outlets are on the same cirute they are affected by the GFI outlet. The GFI outlets do fail at times, and need to be replaced. Have you had recent power outage? Sometimes our "smart devices" are too smart.
If you have power, I'd unplug for a few hours and see if that might reset it's "brain" If that doesn't help you may have a panel problem. Owner's manual? Check troubleshooting section. Warranty?, pursue that. Age of microwave? Consider the cost of repair vs. finding a lightly used "working" microwave.
Mar 03, 2015 | Microwave Ovens
Plug the unit in, hit the power switch nothing not even the lights for the buttons.
Check the outlet that the unit is plugged into, to make sure that it has power. The circuit breaker for that outlet may have been tripped. Also make sure that the outlet is not damaged inside or there could be a loose wire connection or a frayed wire to the outlet.
Hope this helped you to start troubleshooting and solving the problem.
May 18, 2011 | Kenmore 54501 Dehumidifier
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My heaters wont work not sure if its the fuse any ideas ?
I CAN GIVE YOU SOMETHINGS TO CHECK,BUT IF YOU DONOT HAVE THE ABILITY TO USE A VOLT METER IT MAYBE TUFF, FIRST OFF POWER MUST GO TO THE UNIT, YES CHECK THE BREAKER, CHECK AT THE PANEL TO MAKE SURE POWER IS GOING THRU THE BREAKER, NEXT I WOULD CHECK TO SEE IF THAT POWER GOES TO THE UNIT, ASSUMING YOU HAVE POWER AT THE BREAKER AND AT THE UNIT, I WOULD CHECK TO SEE THAT THTHERE IS POWER AT THE THERMOSTAT, CHECK THESE WIRES AT THE UNIT, TO SEE THAT THEY SUPPLY POWER TO THE UNIT CRATEING A DEMAND WHEN IN THE ON POSITION, THESE ARE THE FIRST STEPS, DOES IT HAVE A PILOT ? AND YOU CONTINUE DOWN THE LIST, YOU ARE DEALING WITH ELECTRICITY, IF YOU ARE NOT COMFORTABLE YOU SHOULD GET SOME ONE QUALIFIED, HOPE THIS HELPS, MARK
Jan 24, 2010 | Heating & Cooling
No power, display lights nothing seems to light up, not sure, there is power in the unit though?
Check power into and out of the transformer. You should have either 115 or 230 VAC in and 24 VAC out. If no power out but power in, replace the transformer. If no power in look for tripped GFI, breaker, etc.
Dec 27, 2009 | Pentair Minimax NT Heater
No power on kenmore range
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If everything above is ok, move on to the power cord junction point. make sure the power cord has not separated from the junction point on the backside of the unit.
Jul 16, 2009 | Kitchen Ranges
Breaker switch tripped when ac compressor engaged
The power strip is rated too low for the wattage of the unit and that causes the breaker to trip. I would be better for the unit if it were plugged directly into a wall outlet, because there is less a chance of voltage drop which would burn out the unit. They will only tolerate 10% voltage drop before getting into trouble.
Jul 02, 2009 | Fedders A6P09S2A Air Conditioner
My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
Dec 17, 2008 | Dishwashers
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
