Question about RCA P52939 52" Rear Projection Television
Hit the bottom of tv color still there the pic is double
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 125 Answers
In middle of cassis up above is a small board it will have STK730-010 on this board, replace it Mats has them 1-800-628-1118
Posted on May 11, 2010
I have a double picture and no color on my 19" RCA Model # led19b30rq tv. How can this be fixed
check your single with a nouther tv to see if it working to see if you have single or a color pic this is a lcd tv ?
Nov 20, 2013 | RCA Televison & Video
I have a Hitachi ultravision digital Hd Tv(Model: 43UWXtenB V2A04one295) which shows double or triple color images at the same time. How can I fix this easily ? Thanks for any advices. Sound speaker is...
This tv problems u can't fix it easily,u must take the tv aparts and change an electronic board that call the T-CON board to fixed this problems.If this problems double or triple images not causes by U or an objects by outer forces hitting the LCD screen panel itself,if yes this problems causes by U or an objects by outer forces hitting LCD screen panel itself.This tv problems can't not be repair,because the LCD screen panel itself it is dead and damages leaking radiation,if got hit by an outer forces,if screen damages by outer forces,this tv only can used as salvage tv for it electronic circuit boards for other tvs for as parts only now,because if the tv require a new LCD screen panel will cost the same as a new tv.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish T-CON board for the replacement.
Jul 28, 2011 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Double images on screen
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Feb 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
I have a hp all in one ( printer , color copier , scanner ) and i hit scan and nothing comes up How do i get the picture?
hi,
dear r you have install driver in your system
if yes,
then put a pic in to the scanner and power on printer
and go to your my computer three is icon i think like hpscanner double click on and a window will be opened fallow it for get your pic.
if you driver not install tel me for driver
Dec 13, 2008 | Computers & Internet
Double picture
convergence issue - has the set sustained a knock?
either way, it will require expert help or at very least access to a cross hatch generator
Nov 22, 2008 | Philips 9P5034C 50" Rear Projection...
Pic prob.
WHAT DO I DO FOR MY AUTO CONVERG IT NOT ON MY SETUP OR MY PIC AT ALL MY TV IS OUT OF LINE BAD
Aug 23, 2008 | Zenith R49W36 49" Rear Projection HDTV
Color wheel
Good day, dkimberly428;
Sorry you are having a problem with your SNG TV.
Let me ask you why did you replace the color wheel? Was it making noise, but had pic prior to changing it?
Okay, if that was it, try this: the color wheel ***'y has one cable and "ribbon type" cable, correct? Okay, make sure both cables are secured. Secondly, the "ribbon type cable" was more then likely put in backwards. If I remember correctly the shiny side (end) of ribbon cable should be facing the rear of TV.
Good Luck, big IRISH. PS always double check ALL cables in TV to make sure they are properly seated.
Jul 19, 2008 | Samsung HL-R5677W 56" HDTV
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Help tv is showing double text at bottom and bowing colors
Convergence ICs are bad and need to b replaced there are two of them theyost about 10.00 each.
Jan 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA P52939 52" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
