Question about RIM BlackBerry Pearl 8100
Just bought a Tungston E2 and installed it on myPC. I can't get Hotsync to install my palm desktop info. (Calendar/contacts/memos/doc. to go/etc)on to the handheld. I was successful in installing the books/games/adobe. What can i do?
The problem is still not solved, but I have turned it over to the group that handles equipment under warranty (which mine, being only one week old, is). Instead of paying for your services, I should have been told the other number to call. I request that there be no charge for the time you spent with me. Brooks Goldman
Posted on Mar 30, 2008
SOURCE:
Transfer calendar info from Tungsten/E Palm to iphone 3GS
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Jan 03, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Tungsten E2. Hotsync for calendar runs forever. Suggestions?
My problem was that the Calender app ran and ran during a Hotsync. It would never finish.
My mistake was in dowloading and installing the newest Palm desktop. Version 6.something. It's on the Palm support site.
This caused the problems I encountered. Solution: I copied each categories content to my desktop. Then I deleted the new Palm desktop. After that I downloaded the old desktop software, I think V4.1.4. Almost all of my files stayed intact, so I didn't need the backups that I had saved.
This corrected the problem.
Oct 20, 2009 | Lands Phones
I bought a refurbished Tungsten E. Because there was some incompatibility with the software version of my other Tungsten (which is on its last leg), I downloaded new software off the internet. In the...
Are you syncing the new device to the same username in Palm Desktop as an older device?
If you are, this will cause problems on the new device. When you sync the device, it saves the device settings, 3rd party apps, preferences, etc. in the backup folder in the username folder on the PC. When
you sync the new device it copies the contents of the backup folder for the old device to the new device. This will cause corruption in the settings for the new device thus causing erratic behavior of the new device.
Looks like you may need to hard reset your device and rename your backup folder
Go to http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=887 and follow the directions to do a hard reset. Next before you hotsync your data back over you will need to rename your backup folder, to do that go here;
XP
C:\program files\palm or palm one\[hotsync username]\ and rename your backup
folder to backup.old
Vista
Start-->documents\Palm OS Desktop\[hotsync username]\ and rename your backup
Then hotsync to your current hotsync name and all your contacts, calendar,
tasks, and memos will come back over.
Show file extensions for XP or Vista
XP
If you can not view file extensions on your PC I would like you to open a
folder go to Tools-->Folder Options--> View (tab) and under show hidden
files and folders uncheck hide file extensions for known file types.
Vista
Open control Panel go to Folder Options--> View (tab) and under show hidden
Mar 28, 2009 | Palm Computers & Internet
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
Is Palm Desktop Required when using Outlook?
to be able to hotsync with outlook u need to install the Palm Dektop, and while installing check the option synchronize with outlook. this will install conduits that make the hotsync with outlook possible, and don't forget that only the conatcts, calendar, memos and tasks are synchronized with outlook, the rest (if it is interisting u ) will be synchronized with the PDS. good luck
Sep 12, 2005 | Palm IIIxe Handheld
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Cannot SYNC Outlook Calendar and Contacts
Probably one of these issues - your data is there but you are looking in the wrong place. I am trying to sync my outlook calendar and contacts via Hotsync on a Palm IIIc. It gives me the status of OK, but nothing shows up on the Palm. I have set the custom on Hotsync to desktop overwrites handheld, but still will not work. Thanks.
Sep 11, 2005 | Palm IIIc Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
RIM BlackBerry  Pearl  8100 Logo
66 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
