Question about Dishwashers
Good morning! My Whirlpool dishwasher (I'm at work so don't know the precise number) leaves about an inch of water at the bottom after washing. I called a Whirlpool representative soon after my purchase (post Ike devastation of previous dishwasher that drained fully) and was told that this was rather normal for Whirlppol. I live on Galveston Island in Texas, and adding any more sources of water and humiditiy to my household seems counterproductive. Is there anything that I can do to cause the dishwasher to drain? Is the lack of total drainage truly a typical situation?
  • speloqui May 11, 2010
    So about how much water is typically "normal"
    to see in the dishwasher after a complete cycle has run?
    Can you please be a bit more specific about the rather vague description of "some water." Are we talking about 1/4 inch? 1/2 inch? 1 inch?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 11, 2010
  • Rylee Smith
    Rylee Smith May 11, 2010
    As I said: Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    It should be around 1/4 inch and if the unit is new and still under warranty then you should get it repaired/replaced to avoid future issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
10 year old whirlpool dishwasher model DU810DWOO1 does not completely drain. Leaves about an inch of water in the bottom all the time. The dishes do not get very clean.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Oct 07, 2010 | Dishwashers
I have some standing water in the dishwasher after running
I stopped my dishwasher in the process of dishes being washed because I eas leaving for 2 days & didn't want to leave the dishwasher running. Now I have standing water in the bottom & don't know how to remove it i.e., i.e., short of bailing? HELP!!!
Jun 02, 2010 | Whirlpool GU1200XTLS Stainless Steel...
Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
It sounds like the drain tube is partly clogged.
If you have a shop-vac you could try that. Try to set dishwasher back on discharge,see if water gose out the second time. if it still dont go out it is clogged. goodluck
Aug 12, 2009 | Whirlpool DU850SWPB
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Feb 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
