Question about HP LaserJet 1600 Printer
When we print our labels using this printer, the colours on the left are all faded out & pale for about the first inch & half, all the way down the page - particularly on yellows and pinks. Back to full strength by about 30% of the way across the page. Have tried changing toner cartridges - makes no difference. Any ideas?
    Scholar:
  • 67 Answers
Yes:
1) First, clean the elctrical contact wires in the cartridge bays with alcohol on a Q-tip.
2) Make sure all cartridges are seating completely.
3) Open the front door. Check the wide, black transfer belt (ETB). See if there are uneven wear signs, lines on the belt-side where the colors are faded on the page. If it looks hazey, you can use 95%+ isopropyl and a lint-free cloth to clean the residue off.
4) Remove the ETB and reseat it (may not be easy on this model).
5) Make sure you've tried original hp cartridges -- not only compatibles or refills.
6) If all the above fails, you will need a new ETB. If so, look online by model number "CLJ 1600, ETB".
You may find a refurished on a lot cheaper than new. However, this is a user-consumable component and must be replaced when they wear out.
Posted on May 12, 2010
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
My zebra z4mplus just start printing at the center of the label instead of at the left side of the label. Instead of a normal full printing on a label, now the left half of the label is blank, and the...
Welcome to FixYa.
The Zerba Driver might have been corrupted.
Uninstall the Zebra Driver/Software from the Control Panel.Re-install the Zebra driver using the Disc that came along with the printer.
Thank you for using FixYa.Have a great day.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
CreativeTECH
Feb 26, 2011 | HP LaserJet CP1515n Printer
HP1600 colour fade on one side
it will most likley be the drum take it into a printer shop and they will clean it befor it gets to damaged as they are hard to replace
May 28, 2010 | HP LaserJet 1600 Printer
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
Full colour page print has faded lines printed through the work
I have ordered a new photocunductor unit as i am assuming that the other one was faulty.
Jul 07, 2008 | Epson AcuLaser CX11N All-In-One Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 1600 Printer Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
