Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite dishwasher 8269645: Fills spontaneously between washes (i.e., while not in use), just overflowed.
  • 15,935 Answers
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
2 Suggested Answers
SOURCE: Kenmore Elite 8269645: Fills between cycles
http://www.servicematters.com/maytag_library/docs/16010622.pdf
http://www.partselect.com/dishwasher+repair+repair.htm
Top link is a service troubleshooting manual, below that is a DIY site to help troubleshoot.
Posted on May 11, 2010
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Fills with water till it overflows especially in rinse cycle no matter what water level setting
most probably cause is water level/pressure switch or h hose.  either needs to be replaced or hose needs cleaning or came disconnected..
Jul 20, 2010 | Kenmore Elite 45986 Front Load Washer
Water fills in kenmore elite 16263 but wont wash. It just hums when it supposed to be washing.
HI- The motor is locked up. A seal between the motor and the impeller has worn out causing the shaft bearing to freeze up. Motors are about 100$. Labor should be about the same. Not a defect, just a little shaft seal that only lasts about 4-6 yrs. Let me know if this info helps- ED
Mar 02, 2010 | Kenmore 24 in. 17532 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Washer fills and overflows with water when not in use.
its an easy fix replace the valve the water hoses connect to it has a electric sw that controls that
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher fills and drains but will not cycle into wash ,
HI, the control module is damaged. this component is responsible for initiating the proper sequence. if the logic sector is damaged, it will cause these symptoms that you are experiencing.
Replace the timer or, control board asap.
Jun 24, 2009 | Kenmore Dishwashers
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Nov 13, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
235 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
