Question about Linksys RV042 VPN Router
I have a static ip address for my server, how do i setup the router so i can access the internet?
  • 4,281 Answers
There is 2 method for it.
first connect your server directly to router lan port and configure your router as bridge mode.
Thenn set static ip address in your server lan property.
Seconds configure your router as static ip set in wan settings that static ip and set in NAT settings and open all port and forward that traffic to your server lan ip address.So you can access server from internet .
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 11, 2010
2 Suggested Answers
ihwsolutions
  • 137 Answers
SOURCE: D-Link DIR 655 - DHCP server but no internet
This usually happens when the router has timed out trying to grab an IP address from your modem.
I suggest unplugging your router and modem, waiting 1 minute, plugging in your modem, wait 1 minute, plug in your router, wait 1 minute, then try to connect again.
If this solution has helped you, please take the time to rate me.
Posted on Oct 04, 2009
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet connection...
DNS-servers translate names, such as 'www.fixya.com' to IP-addresses, because routing of IP-packets on the Internet is done using the IP-addresses, not by using the names of each computer.
If you have a router between your computers and your cable-modem (or DSL-modem), then the router can automatically supply the "Primary DNS Server" and "Secondary DNS Server" and "IP Address" to your server computer, if you configure the network-adapter on the server to "automatically obtain an IP Address".
As long as you leave your server running, the "dynamic" IP-address that it obtains will, in effect, become a "static" (namely "non-changing") IP-address.
Feb 03, 2011 | Computers & Internet
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Unable to access Internet, WAN IP Address present
First you will need to open up your internet browser (Internet Explorer/Netscape) and go to http://192.168.1.1. You will be prompted for a username and password. By default there is no username and the password is admin. Once you arrive at the routers setup page click on the Advanced tab. Once the page finishes loading, you'll find you will be on the "Filters" tab. Look down and make sure that there are no numbers other than 0 in the boxes on that page. If there are, then you will need to replace them with 0's and click Apply, then Continue. Once you've done that, you're going to want to look for Dynamic Routing at the top, and then click on it. Once that page finishes loading, make sure that the "Working Mode" is set to Gateway, not ?Router?, and that tx and rx are set to Disable not RIP-1 or RIP-2. If a static IP address has been set on the computer, verify the gateways matches the Router's LAN IP Address. If there aren't any installed gateways, add the Router's LAN IP Address. When setting static IP Addresses, you must also input the DNS servers. For more information on assigning static IP addresses, please see the related article on assigning static IP addresses. If you?re still having difficulties, please contact Linksys Product Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
Feb 16, 2006 | Linksys BEFSR11 Router
Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Feb 16, 2006 | Linksys WRT55AG Router
Linksys RV042 VPN Router Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
