Question about IBM WorkPad c3
IBM workpadc3 how can I turn on the backlight
Hold the power button or 3 sec.
Posted on Jun 22, 2008
LCD backlight replacement
If the LCD screen on your IBM laptop is going dim, chances are the backlight is breaking down. The good news is that if you don't want to spend the money to have a technician replace it, you can do it yourself. There's no need to open up the main body of the computer, but you will have to get into the screen to do the work. Here's how.
Power off your IBM and remove the battery. Remove the nine screws (three on each side) on the side of the screen. Once the screws are removed, the plastic bezel (screen guard) can be removed. Pop the bezel out, exposing all of the LCD screen. Pull the LCD screen gently away from the computer by the corner. Be mindful that the screen is still connected to the computer by a ribbon cable. Remove the tape over the ribbon cable where it connects to the screen and gently pull the cable to disconnect it. Turn the LCD facedown, and remove the piece of tape that holds the top metallic foil against the back of the LCD. Lift the metallic foil to expose the backlight. Remove the single screw at the end of it that holds it in place. Unclip the wire at the end of the backlight from the inverter (power source to the backlight), and remove it from the LCD. Replace it with the new backlight (available at any electronics store or online). Be sure the new backlight is compatible with your particular IBM model. Reassemble the computer reversing the order in which you took it apart.
Remontage / reassembly Lenovo Thinkpad T60 ou T61 all versions http://www.youtube.com/watch?v=dxNB3sxUfos ThinkPad Back Light Replacement http://www.youtube.com/watch?v=tr_trXGEYT4 IBM lenovo T61 display problem http://www.youtube.com/watch?v=Em6XBA_nOZ4
Feb 05, 2013 | IBM Lenovo ThinkPad T61 Notebook
IBM T43 laptop display
This is an example of an inverter going out slowly. Usually, they tend to just go out and you diagnosed correctly when you seen the faintness on the screen and tested with another monitor.
The Dell inverter will not fit, more than likely. They are all different sizes, lengths, etc.
I would recommend just replacing the screen of the Toshiba. You can get one for less that $50.00 on eBay and it will save you alot of hassle trying to swap out the inverter (my opinion).
Oct 04, 2009 | IBM ThinkPad T43 Notebook
Hi, the backlight on my screen no longer turns on but i could see windows running so i know that the screen is not broken. i was thinking that the inverter is probably the problem, but if not how can i...
The backlight is normall part of the LCD panel assembly and is not normally changeable on its own (sadly) however here is a link to one being solf on ebay http://cgi.ebay.com.au/LCD-CCFL-Backlight-Lamp-for-IBM-lenovo-ThinkPad-X60-X61_W0QQitemZ250464679317QQcmdZViewItemQQimsxZ20090715?IMSfp=TL090715205001r13604
and here is a link to the X61 LCD dissassembly http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
After removing the LCD you will gently have to prise it apart to reveal the backlight assy. Hope this goes will for you.
Aug 11, 2009 | IBM ThinkPad X60 Tablet PC
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Need help to change language for Palm OS
You NEED to Post this in a Different Forum Category!!
You are in "Air Compressors"??
Jan 27, 2009 | Air Tools & Compressors
No backlight
with a multimeter verify if you have power in inverter, if not, try to connect the inverter to another power supply for testing.
Jan 06, 2009 | IBM ThinkPad T41 Notebook
IBM THINKPAD SCREEN DEAD
Since you have replaced the inverter and the unit works with an external monitor, then probably problems would be with:
  • CCF lamps (backlight);
  • inverter triggers and/or B+ supply.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | IBM ThinkPad T23 2647 Notebook
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
Ibm t20 no LCD backlight
while the T20 is on and manifesting the dim display....
1. try to slowly close the lid (but not totally closing it) and then pulling it back to its original position slowly. Tell me if the light goes back.
if by doing that action the backlight lights up, you are most likely faced with a Flex cable problem. You might need to buy this from ebay. (dim display problem in T20 series is very common these days due to wear and tear of the flex cable)
2. Also try to use a pen to turn on and off the limit switch that triggers the backlight. This is located above the keyboard below the lcd. See what happens.
Apr 10, 2008 | IBM ThinkPad T20 2647 Notebook
Backlight problem
if this is a new laptop, then I am guessing you are using it on battery, and you may have some power save setting turned on that is dimming the screen...
Take a look at your power settings under control panel...
M
Jan 01, 2008 | IBM ThinkPad T43 Notebook
IBM WorkPad c3 Logo
186 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
