Question about Sharp AL-1551CS Copier
Sharp AL-1551CS Scan Problem
I can still scan copies from the platen, but when I scan from the ADF the copies come out black. It also seems like it will scan an 8"x11" sheet of paper. When scanning a 8"x14" paper the last 3" of the scan is black. Is the a problem with the scanning hardware? Could it be a broken cable on the scan hardware or needing an adjustment on the scanner travel mechanism?
  • 59 Answers
Hi do u have set tha adf limet for 8"x14" just set the corect size of origlan from adf
thanks
Posted on May 15, 2010
  • Sharp Master
  • 12,061 Answers
Http://www.eserviceinfo.com/downloadsm/27055/Sharp_AL-1215,%20AL-1530CS,%20AL-1540CS,%20AL-1551CS.html
http://www.scribd.com/doc/12846272/Sharp-Service-Manual-AL1530-1631-1641-1645
www.cyberscholar.com/sharp/.../cop_man_ALCSOnlineManual.pdf Above are service and user manuals these will help you troubleshoot.
Posted on May 11, 2010
How do you scan?
Hi kebranch,
To scan the documents, pictures etc., This are the step just follow,
1. Scanning using the Operation Panel
2. Load the document on the platen glass or in the ADF.
3. Press the [Scan] button on the machine.
4. Then the machine switches to Scan Mode
6. Press the [Color Start] or [Black Start] button on the machine
7. MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass or in the ADF using MP Navigator.
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Canon Pixma MP450 All-In-One InkJet...
Black line in paper
On what operation are you receiving the black line in your paper?
This problem usually appears when you try to scan or copy using your ADF (automatic document feeder).
To remove this black line in your paper, clean the ADF platen glass in your printer and do as well in the flatbed scanner glass. This ADF platen glass can be found right below where the documents in the ADF goes through. Its a glass about 1 inch in with and beside the flatbed scanner glass (the one where your documents is lay down for copying and scanning. Dried ink or paper residue sticked in the glass can cause this line in the paper. Clean it with a a clothe and spray some windex on it.
Feb 10, 2011 | Panasonic KX-FLB801 All-In-One Laser...
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Dec 15, 2010 | Canon PIXMA MX310 All-In-One Printer
How do use the scan.
The machine switches to Scan Mode
Nov 23, 2010 | Canon Pixma MP450 All-In-One InkJet...
In copy or scan mode, the page is almost all solid black
The scan assembly has gone out. Parts are not available except the entire scan assembly, I can get you a part number and price if you like.
Jun 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Head unit wont scan
Clean the underside of the platen glass, be careful to remove the screws, also there is a plastic cover at the top of the platen under it there is a white correction plate clean this plate with cloth.
Feb 06, 2009 | Sharp AL 1631 Copier
Dark lines on only document feeder copies, Sharp AL 1631copier
If you have the ADF installed then you should have 2 document glass, the ADF uses the small one to scan the original, if this glass is dirty even a small dot will become a long line on the copy result. Clean this glass.
Nov 02, 2008 | Sharp SHP AM900 multifunction Printer
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
137 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
