Question about Canon MP640 All-In-One InkJet Printer
Hi, how do I remove a print head from a Canon MP 640, thanks, Jenny
  • 109 Answers
As i know newer canon inket pirnter, the printer head are not user removable, you have to bring it to a service center for such job..
Posted on May 11, 2010
  • Kay519 Mar 27, 2011
    The MP460 when first unpacked has not got the print head fitted as it is packed separately. Full instructions in installation handbook. Basically, turn on printer then lift top covers as if changing print cartridge. Head carrier moved to central position. Remove all colour cartridges and place immediately in a sealable polythene bag, to prevent drying out. Lift up grey plastic frame surrounding head carrier to vertical osition then push back to limit. Lift front of exposed head at a slight angle then remove towards you. Clean head with Methylated spirits and cotton bud. Hope this helps.
Remove print head canon mp480
THe print heads are an integral part of each cartridge. When you remove the cartridges you actually remove the print heads. You will need to open the top front panel to access the print carriage which moves left and right over the paper under it. Using cotton swabs you can apply rubbing alcohol to the places the cartridges rest upon and absorb all the dried out ink. Be sure you toss the old cartridges out before you reassemble. If you need to store any ink type printers REMOVE ALL CARTRIDGES and clean off the receivers on the print carriage!
Dec 31, 2012 | Canon Pixma MP480 All-In-One InkJet...
Mp 730 "Wrong Cartridge" have been using same cartridge w/o any problems
the cartrige has become faulty or the wire strip that connects to the cartrige holder is comming out or a wire in the strip is broke , a new cartrige would then do the same thing
Oct 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Lights flashing says print head is incorrect,install correct print head,but it was the same print head,it just appear..canon pixus mp 600,what can I do plse
Hi. Unplug the printer from its power and try this.1. Pull the cartridges out 2. Remove the print head, and re-install making sure the metal contacts on the side line up with the ones in the printer. it can appear to be in OK but use a strong light to make sure it is lined up correctly. 3. Re-Install the cartridges and try again.
This can also happen with some compatible cartridges or ones that have been re-filled and re-set too many times. The black cartridge is usually the issue in this case.
I hope this helps Regards GM
Apr 10, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My MP 145 Canon cannot print red colour, but other colour are fine, what should i do? thank you
Check the Magenta cartridge, is ir empty?
Do a maintenance head cleaning (do a deep clean) - check the Magenta print head, is it still blocked.
Oct 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Mp 510 printer does not print
mine is the same. did you find a solution to this problem?
Feb 15, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Error 5100 on canon mp 160
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Hope it do for you
All The Best: Pineworks
Nov 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP 600 will not print red
If you do the self test or self cleaning operations does it print red on that? If it does then the issue sounds more like a software issue rather than the hardware. If that is the case then I'd uninstall and reinstall the software drivers and see if that helps. You could also just try cleaning the heads on the red cartridge. Remove the red cart. then use a cotton bud and alcohol (I used my wifes nail varnish remover) to wipe the heads clean and dry it.
Jun 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I want to know if I can print without USB using my wireless, I have a Canon pixma mp160.
Canon Pixma MP 160 do not support Wireless Interface
So you will need to connect it to USB port in order to print the documents
Interface
USB 2.0 Hi-Speed3
Direct Print Port
Specifications for Canon MP 160
You can refer the Canon MP 160 Manual for further inofrmation
I hope the above resolves your query
all the best
Do rate the Solution, as we can guide others accordingly
Thanks in advance
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Nov 21, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP640 All-In-One InkJet Printer Logo
4,124 people viewed this question
old marine
old marine
