Question about Bosch Dryers
Bosch wta 2000 drier not working
I have a Bosch wta 2000. When the time is selected and the start button is pressed, the light comes on as normal but the motorr does not start. Any suggestions, please? Thanks, Emmet
  • emmet61 May 14, 2010
    The solution was useful in helping me assess whether an economic repair was possible. Thank you.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 11, 2010
My washing machine is beeping and showing the key light and not turning on. The door opens though but it seems to be saying its locked!? It doesn't show the cycle time either. How can i get it to go...
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch, but you didn't specify the model number. It sounds like the "child lock" selection has been activated, either intentional or accidental.
To reset it on many Bosch it is as follows...(if this fails, please provide your model number)
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for choosing FixYa. I'll need to watch for your reply if that doesn't work or before moving forward.
Regards,
Macmarkus :)
Aug 16, 2011 | Bosch Washing Machines
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
82 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
