Question about Baumatic 27 in. B67 Gas Cooktop
Gas hob ignition firing, won't stop
Baumatic gas hob ignition is firing and won't stop. Three out of five rings ignition are firing without turning the control knob. Started after had cleaned the hob. Has fused the house. Turning off the electricity just to oven not curing problem, only when turn off electricity at fusebox does it stop - but then no electricity in the house!
Not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
Posted on Jul 05, 2010
The ignitor on my AEG gas hob keeps firing. I have not spilt anything on it.
Take the switch buttons off and use a hairdryer to blow dirt out and dry up any damp. Also make sure buttons go up and down cleanly.
Mar 03, 2011 | Baumatic 27 in. B67 Gas Cooktop
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
My baumatic hob keeps sparking for no reason! i was cleaning it and now they keep sparking and i dont know what to do! also, is it dangerous, will gas be leaking?
No. You have some moisture around your igniters. They will stop eventually or you can use a hair dryer to help them along.
Jan 31, 2010 | Baumatic 23 in. BT62 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Baumatic 27 in. B67 Gas Cooktop Logo
2,715 people viewed this question
Top Baumatic Cooktops Experts
Rod Doney
Rod Doney
The Vanguardian
The Vanguardian
Pete
Pete
Level 1 Expert
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
