Question about Audiovox AVT-1475 13" TV
Missing fuse and fuse cap.
The tv is missing the fuse and the fuse cap. We have looked online to find parts numbers or where to get the parts without any luck.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 125 Answers
PartStore.com 1-866-925-7278
Mats Electronics 1-800-628-1118
Posted on May 11, 2010
Missing filter cap
Fixya does not sell parts and is unable to suggest sources.
Jul 28, 2017 | Daewoo Washing Machines
Tip
How to fix convergence problems for RCA chassis ITC222.
Your projection TV looks like you are watching 3D video and none of the colored beams are aligned. You go to the menu to set the convergence and find that the convergence adjustment menu is missing. What is causing this?
Basically you need three parts which will be installed in the area of the flyback transformer. An electrolytic capacitor, a fuse and a diode. This circuit supplies dc power for the convergence circuit and without it the convergence circuit will not work. Without convergence correction your unit will look like it is in 3D and you will have red and blue shadows around all text, etc.
You need to get a kit at http://www.tvrepairworld.com/rca_repair_kits . You want the one labeled ITC222 and ITC222A convergence option missing repair kit. It comes with very good instructions and appropriate schematics to make the repair possible by anyone. In addition there are videos available on the parts website to help with the repair.
This kit will fix the problem with the missing convergence menu but may not fix all the problems with the miss-convergence in the unit. If it does not solve all the problems go to my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help with further troubleshooting. You could also have problems with the convergence board, which may have blown out the power supply for the circuit in the first place.
Thanks for using FixYa and for the great rating.
hardrocko
on Jun 18, 2010 | Televison & Video
Coil grounding on it;s self 94 k1500
that should be HEI so the coil is under the cap. so how can you see it arc its probably a wire arcing replace them
Feb 11, 2013 | 1994 Chevrolet K1500
What is the code in the rca rcu404?
a UNIVERSAL is a waste of money--if you try enough codes it will likely only turn on or off and maybe volume--it will be missing a lot of essential features the original had. If original is lost look for an exact remote--by model number---with that model you can call Panasonic customer service and get the part number and a price and availability for it or search online to see if someone else sells it.
Apr 26, 2012 | Panasonic PVQ-2512 25 in. TV/VCR Combo
Safco Drawing Clamps Missing End Caps
go online type in lids or container tops, screw ends, and the size you need and see if you can get any hits or
if you know the manufacture name of product than type in there name and replacement parts
rod
Feb 26, 2009 | Safco Telescoping Document Tube, Expands...
Hello, I just received a used Toshiba tecra 9000 laptop and it is missing the "mouse" and I need a part number so I may buy one.
Since the Tecra 9000's mouse is actually the Accupoint that's located within the keyboard, it cannot possible be missing the mouse (unless it's missing the keyboard).
Unless you're missing the Accupoint cap. Only place to order them is from Toshiba Support.
Feb 03, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Looking for schematic of Hitachi 43FDX01B TV- 18 pin transistor
The parts that are missing are likely to be the convergence ICs. These are STK392-110 and should be available online from any electonics parts supplier. Expect a cost of around $25 each.
Dan
Dec 26, 2008 | Hitachi 43FDX01B TV
Acer schematics / parts lists - my PCBs are missing capacitors!
It is common to have a lot of missing caps. in all types of boards
they may leave out a chip and not need them
or find that the put too much load on the wiring .
a cap is just a small battery and filter for a part of the circut that draws more than the wiring supports, and lets the chips do burst speed without waiting for the power to rise.
if you have a power on off cycle look for heat rise in transistors.
but usually its a cap overloading.
not easy to trace. also look for bulging caps on the top of them.
Aug 06, 2008 | Acer AL1912 19" LCD Monitor
Sanyo tv tuner identification
I have the sanyo part # 6450526084 . There is another number but could not find it online. There is a place called www.tiptoptuner.com that might sell you the tuner outright as they mostly rebuild them . The are the cheapest place i know of . You want to use the contact link and tell them the part # and see if they can cross it for you as i gave you part number. The ID # you refer to is on the tuner shield that you say is missing . Or you can google the part # to see what you can find should start with 1AV4FBAM???? . Good luck
Jan 13, 2008 | Sanyo DS31520 31" TV
Audiovox AVT-1475 13" TV Logo
145 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
