Question about Jasman Command Force RC Tank
It does not seem to work buy the controler just the demo
  • 2 more comments
  • timothy schupp May 11, 2010
    of cource i checked and changed all the batt'
    this jasman tank still not responding to it's hand held remote controll
    sorry but your not even close it is a 49 meg unit so i guess i'll be talking to someone else sorry
    this is a 49 meg unitthe demo work's great but the controller not at all but i do belive i can fix so i'll let you all what the reason was cince sofar no one no's what thay r talking about
    President:
  • 1,297 Answers
Change the batteries
does this have the changeable frequency inputs?
try changing that too
Posted on May 11, 2010
  • 2,069 Answers
I should inform you that It operates at 27Mhz frequency.
  • Muzahura Frank May 11, 2010
    what I'm informing you is that It operates at 27Mhz frequency and also operates at a max of 10-15 feet (It will cut off after that.). the controller you are talking about is a radio controller and is susceptible to the above conditions. so please check that it is set within that range.
    President:
  • 4,070 Answers
Hi! Have you checked the battery of the cotroller? Its battery operated and the battery may be faulty. You will need to replace it for it to work. Hope this helps and have a good one!
Where can i buy a reset button for a reddy heater model r35a ser # 333692
The reset button is part of a safety control assembly acting as a circuit breaker when the photocell detects that the flame is not firing properly.
This is a pretty expensive item, so you may want to check that it's in fact bad before getting one.
It may be that the photocell is dirty, or your heater is not firing properly, causing it to trip.
Is the replacement because it doesn't seem to be working or is it missing?
http://www.cart32hosting.com/cgi-bin/cart32.exe/REDDYPARTS-store?catid=14&prodid=36&Theme=Demo
Feb 12, 2011 | Reddy Heating & Cooling
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
Micro wave cuts out after 20ish seconds
Try this...
Press: Function 0 2 to turn off demo mode. For future reference, Function 0 1 should turn demo mode back on.
Feb 01, 2009 | Panasonic Microwave Ovens
Racing wheel setup
OK, at least for my issues, after talking to MS support ...
Here was the issue with the Setup disc (Forza Demo): If it jumps into the demo ... the XBOX DOES NOT need to be updated.
As for not connecting to the XBOX (Sync'ing up the controllers) ...
You need to press the SYNC (located by the memory card slots)Button BEFORE you PRESS the SYNC button on the wheel controller. Once you do that (a step that is not clearly pointed out in the stupid an poorly written manual) all worked asa expected. A Simple hook-up procedeure that took 2 days because of a step that was not pointed out or not made obvious to the XBox Parents and non users.
Dec 25, 2008 | Microsoft Wireless Racing Wheel for Xbox...
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
Demo will not turn off
Hello!, i'm the same problem with a eh-770 before a cut of electric fluid. I resolved the problem setting the clock of the unit.
Jun 07, 2008 | Technics Audio Players & Recorders
Inverting color display
To cancel demo mode: While unit is OFF and ignition is ACC or ON, press "display" to cancel.
To cancel reverse demo: While unit is OFF and ignition is ACC or ON, press "band" to cancel.
You can also use the MULTI-CONTROL to turn demo mode OFF.
May 15, 2008 | Pioneer DEH-P5900IB CD Player
Message on screen
In demo mode? Hold both vol up & chan up at the same time for four seconds-that will release demo mode.
Oct 04, 2007 | Philips Magnavox 27MS343S 27" TV
Cant turn off the demo mode
There is often confusion in the way the manual states how to achieve removing demo mode. Because this is listed in the "Menu System" section of the manual and assumes you read from page 1 of the manual that you will know to enter the menu in this section of the manual. Here is step by step instructions on removing demo mode on your unit. 1. Go to standby mode 2. Press and hold the menu button till the menu comes up 3. Press control knob towards AM or FM to scroll through menu till you locate "Demo On" 4. Press control knob straight in for approximately 3 seconds till it switches to "Demo Off" 5. Hit menu button again to exit menu
Apr 05, 2007 | Kenwood KDC-MP732 CD Player
Demo mode problem
From the user's manual (pg.23): 1. Select the Demonstration Mode. Push the Control knob towards [FM] or [AM]. Select the "DEMO" display. 2. Set the Demonstration Mode. Press the Control knob for at least 2 seconds.
Feb 13, 2007 | Kenwood KDC-MP232 CD Player
Jasman Command Force RC Tank Logo
47 people viewed this question
Top Jasman Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Jasman Toy Expert? Answer questions, earn points and help others
