Question about Garden
Cant find owners manual for troy bilt ltx-1842 lawn tractor
5 Suggested Answers
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 15 Answers
SOURCE: tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Posted on Mar 25, 2010
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Posted on Apr 19, 2010
    • 407 Answers
    SOURCE: how to replace the top
    Unfortunately there is no easy way to do that.I find that removing the seat and rear fenders is the best way to get at the engine pulley.I remove the deck and the deck belt then drop the belt from the engine to the front.Make sure to get the belt inside the tension pulley before you put it on the front pulley.You will need a small pry bar or large screw driver to get the belt on the last pulley.Before you use one of those wrap it in an old rag or some leather(old belts work)to keep from damaging the belt.I would suggest replacing the deck belt while you are down there,I always change both as it is not much fun to change the belts.
    Thanks for using Fix Ya.
    Posted on Jun 11, 2011
    How to wire solenoid on Troy Bilt ltx 1842
    Didn't specify solenoid of the two so is a link to the wiring diagram.
    http://c.searspartsdirect.com/lis_png/PLDM/P0401171-00010.png
    Oct 29, 2014 | Garden
    How do I replace a belt for a TB515EC troy bilt lawn edger
    The owners manual should have belt routing diagram, or Google Troy-Bilt, enter your model number and look at there PFD download manual.
    Oct 03, 2014 | Troy Garden
    How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
    You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
    At top right click on owner center and follow directions.
    Mustang 50 XP Zero Turn Riding Lawn Mower
    Sep 11, 2014 | Garden
    Need to put a new belt on the rear of the Troy-Bilt LTX 1842
    First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
    Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
    Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
  • Nov 30, 2009 | Mtd Garden
    I need to locate the fuel filter for a lawn tractor ltx-1842
    Locate the fuel line at the carburetor and trace it backwards toward the fuel tank. You will find a (usually plastic) in-line filter somewhere near the back corner of the engine
    Aug 25, 2009 | Garden
    Troy Bilt 1842 Tractor wont start, replaced started, solenoid..
    Most of the starts but dies problems are caused by dirt/water/debris in the carburetor float bowl.
    You can try draining the gas out of the carburetor float bowl by removing the float bowl nut located on the bottom of the carburetor.
    Make sure the hole in the float bowl nut are clean. If the problem persists after draining the float bowl nut you will have to remove, dis-assemble and clean the carb with compressed air and carb cleaner.
    Aug 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Require an operator's manual for a bolen troy bilt ltx 14 hydro
    Jun 19, 2009 | Garden
    Garden Logo
    250 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
