Question about Toaster Ovens
How to set the clock on Nardi built-in stove (model FE46?) Thanks.
There are 6 push buttons, the two on the right have a plus and a minus sign on them. Just use these to set the clock.
Posted on Jun 23, 2014
What setting should i use to cook food in the oven,
pick one and go,you see,we dont know what stove you are talking about or what settings because you failed to tell us these things in both questions
Apr 23, 2015 | Better Toaster Ovens
How to set the clock on classic 110 oven
Push the clock button. Either use the timer up down to set a time. Push the clock button again. Should lock in the new time..
Oct 30, 2011 | Toaster Ovens
The oven turns on and works fine but I'm unable to turn it off. i have to go flip the breaker to turn it off. The clock does not appear to be right up against the screen, at times temp/clock fades in and...
If your unit is already old enough, I think it will need to replace many parts. So it is worth buying a new one than to repair it because many parts will be replaced soon. I hope I give you some idea.
Mar 21, 2011 | Magic Chef Toaster Ovens
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Wolf 4 burner stove developed a non stop ignitor clicking
If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Igniter on Wolf Stove clicks continuosly
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Non stop ignitor clicking
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
I have a new toaster oven and the clock won't set properly
I would call Cuisinart - this one has a 3-year warranty, and all they would need is a serial number, not the receipt. Do any of the lights turn on? When you pressed clock, did you hold in the hours button?
-Tha Mp3 Doctor
Jan 07, 2009 | Cuisinart TOB-175 1500 Watts Toaster Oven...
EURO PRO TO31 MANUAL
have to hold the clock button in till it shows the 24 hour or 12 hour. After you pick which setting then use the up down key to adjust hour then hit clock again then set the minute with the up and down keys.
Jul 04, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Toaster Ovens Logo
405 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
