Question about Linksys RV042 VPN Router
Hooking up two routers to the modem
How do i hookup a vpn router and a wireless router to my dsl modem?
  • 4,281 Answers
Connect ethernet cable from DSL to vpn router and set wan settings in vpn router as your internet service provider settings.
then connect your wireless router to vpn router with ethernet lan cable on lan port.For that you need to configure router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
When you connect vpn router to wireless router set in wi fi lan property as your vpn network range set vpn router ip as gateway ip of wireless router.Then save settings and restart it.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 11, 2010
What is dsl modem?
Yes it can. The DSL modem is hooked to the phone line or cable and a network cable comes out of it. You hook that cable to the WAN port on the rout
Aug 19, 2014 | NetGear N600 Wireless Dual Band Gigabit...
My HP a6200n won't connect to the internet. it says it's connected to and unidentified network. It is a DSL hookup and I also have a wireless router hooked to it the router is pumping out signal which is...
directly connect the dsl modem to your pc and then restart your system. once your up and running the pc should automatically create a connection with the modem device. once you have established an internet connewction this way, shut down the system and reboot. after complete bootup, unplug the power supply cords to both the modem and the router. now plug im the modem, wait 1 minute and plug in the router. after about a minute you should now be able to connect to the internet both by your pc and wireless connections.
Jan 17, 2011 | HP Hewlett Packard Pavilion A6200N PC...
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
May 03, 2010 | 2wire (1000-400108-001) Router
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
How do I hook up a wireless router to dsl
Simple enough the setup will be as follows:
DSL Modem---->Wireless Router----->Computer
all you need are the proper cables like the ethernet or rj45 cables to connect your modem to router to computer....
for further assistance please provide complete details of the name and model number of dsl modem and wireless router....
Oct 24, 2009 | Belkin Computers & Internet
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Wireless router
modem to inter net or wan port on this router>and u have 4 ether net od lan use any one -->ether net cable to pc's>and if u r using cable inter net then reboot the both router and modem u can get inter net access if its dsl contact linksys cause need to configure teh router rate me solved if its help full thx
Oct 29, 2007 | Linksys EtherFast Cable/DSL VPN Router...
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Connecting VPN using Netgear 624
This is no small undertaking. You will first have to decide if you are going to use software or hardware vpn. Software vpn is free and only requires that you install it (the client) on whatever remote system you are using to connect to the 624. I can say that you want to have your internet connection point (DSL modem or Cable modem) set to "bridge" mode. This will pass through all traffic to the netgear directly. Some (like a speedstream 5200 DSL modem) allow this or they have a DMZ feature which will accomplish the same. Either way you want to ensure ALL ports and all traffic are getting to the netgear. Once that is done you simple create a string at both ends that match for your security phrase and an authentication that matches and you should be good. It's really a lot more than what could be provided here. (Several lengthy documents worth) but I can provide you with a useful link that will give you an a-z about VPN and has specific walkthroughs for Netgear users only. http://www.vpncasestudy.com/index.html Hope this helps a little.
Aug 22, 2007 | NetGear WGT624 Wireless Router
Linksys RV042 VPN Router Logo
65 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
