Question about Roper REX4634KQ Electric Dryer
Dry does not heat up
We moved the dryer from our house to our son's house and it runs now but does not heat up
  • 5,911 Answers
If your dryer runs, but does NOT heat, the following two links can give you some added advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
Read through the information I provided and, if you have any questions. I'm assuming this is a Whirlpool manufactured Electric Dryer (Roper), because of the illustration you posted the question under. I hope you find this information is helpful.
NOTE: If this an older dryer, some of the heating components can become fragile over years of use. Moving it from one residence to another can cause them to break. In particular, the heating element coil. In addition, if you removed the power cord to the dryer, make sure you have connected it correctly. The following link explains how the power cord should be installed:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you would like some added advice that can help you in the future, Repairclinic.com has a repair manual that you can purchase that you can to help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on May 11, 2010
Just moved into a house and my dryer will not heat up like it did in old house ?
One of the 110v phases doesn't have power or moving damage. Check breakers/Fuses on panel, and be sure the socket isn't damaged behind the dryer. BE SAFE!
Oct 24, 2014 | Got2b Rockin It Encore Finish Dry...
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Dryer runs, timer moves, clothes do not dry, dryer
If Electric then could be elements or thermostat...Check 1st not cut out operated....
Nov 11, 2009 | Kitchen Appliances - Others
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
My Son's dryer shuts down about 20 minutes into the drying cycle
Most dryer heat related problems can be attributed to poorly installed, kinked or clogged dryer ventilation ducting. It sounds like the Thermal Fuse may be beginning to fail. I have experienced this problem on only one other occasion. Normally the Thermal Fuse will blow (like a fuse is supposed to) and has to be replaced. However, I did have a problem similar to yours where the fuse would trip when it was hot, but when it cooled, the dryer worked fine. Now if you are having problems with the Thermal Fuse tripping, its generally for a reason. If the dryer exhaust vent ducting, or dryer interior has not been checked or cleaned recently, I would recommend doing so now.
A simple test that you can try is to remove the dryer vent hose from the back of the dryer and dry a load of clothes as you normally would. The air coming out of the exhaust vent should be forceful and warm (about 140 degrees F). If your clothes dry normally, with no problems, I would recommend checking the ducting at the point where it leaves the dryer to where it exits your home. Locate and fix any sags, kinks or choke points that can lint to accumulate and clog.
If you have weak air flow, or if the dyrer shuts down like you been experiencing, I would begin by checking the dryer interior for clogs. In most cases, the dryer blower fan housing becomes built of with lint and can cause the dryer malfunction.
Cleaning the lint screens on these dryers is not always enough. Routine inspections of the dryer ducting and cabinet interior should be done about every 3 months. A dryer that remains in a clogged condition will actually run hotter, but dry less efficiently. This causes the heating circuits to run at higher temperatures. Sometimes to the point of failure. The also can cause a fire hazard.
The Thermal fuse is a small plastic looking component mounted on the blower fan housing with 2 wires attached to it. The other component that you may have on the blower fan housing is the operating (or bias) thermostat. It usually has 4 wires attached to it. With the dryer UNPLUGGED, you can disconnect the wires on the Thermal Fuse and take a resistance reading. It should read a short (0 ohms) if good. If bad, this reading will change when the component gets hot. The way I isolated my fault was to run the dryer until it failed, then took a quick resistance reading.
Let me know if you have any questions. I hope you find this information helpful.
Jun 27, 2009 | Kenmore 63942 Dryer
Dryer will not dry clothes
make sure the vent is clear that runs to the outside of the house.
Jun 26, 2009 | GE DCSR483EA Electric Dryer
When the start button is pressed and held down the dryer will run but when the button is not being held dowm the dryer cuts off. What could that be? It is a Kenmore 90 Plus Series Even Heat Dryer
i would say that it is in the "lockup" circuit in your motor. there is a centifugal switch which moves when it senses RPM of the motor which then in turn closes a set of contacts within the motor housing, thus locking the run contacts to keep your motor running. odds are that the switch, (which moves along the motor shaft) is dry or blocked by debris (lint) that gets caught in the motor housing.
a good cleaning and then a shot of lube on the shaft usuallly solves this problem....
good luck; jay
Mar 21, 2009 | Kenmore 62622 Electric Dryer
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Roper REX4634KQ Electric Dryer Logo
121 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
