Question about Samsung CLP-610ND + Demo Laser Printer
I have samsung CLP610nd printer. and it's printing vertical blue smears on the paper. what is the problem and how to rectify it please
    Scholar:
  • Samsung Expert
  • 113 Answers
have you tried replace the (C) toner. it might be the toner drum issue. and if the rest of the color is working fine. then there is no major issue.
just replace the (C) toner will do.
Posted on May 13, 2010
Smearing of printed image in color printing mode
many times this problem is caused by the type of paper being used, especially with photos, try a different paper, or change the type of paper in the print box when you try to print. the amount of toner used is determined by the paper type. if you are printing on glossy paper you might get the smearing if you didn't tell the printer to print on "glossy" Anyway, this is most likely where to problem can be solved. good luck
Mar 24, 2011 | Samsung CLP 300 Laser Printer
The document printed from samsung scx 4200 printer has smudges and dots.
When you say smudges, can you wipe the toner from the page with your fingers; or is it just smearing when it prints; but, the toner is affixed to the paper?
1) If you can smear it with your fingers; replace the fuser. It's not heating the toner properly
2) If it is smearing, but sticking; replace the DRUM.
Nov 07, 2010 | Samsung SCX 4200 All-In-One Laser Printer
The red light has come on - mid-way through printing, and nothing I do seems to rectify the problem. It won't print. Just got the blue and red lights on all the time
Many things can cause that, toner box full, fuser not heating, paper empty, toner empty, paper scraps inside, imaging belt used up, If the owners manual doesn't help you locate the problem you may need a shop. Samsung customer support can help too, you'll find their number on line.
Jan 25, 2010 | Samsung CLP-315W Laser Color Printer
Samsung clp610nd paper jam 1 issues
Hello there
You may not see a paper jam, this is worth a try.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well. get more help for Samsung Carriage Jam .
Jun 26, 2009 | Samsung Office Equipment & Supplies
Print Quality Problem
Hi jepeto997:
Try these steps.
Check for and remove any media, jammed
paper, or debris found in the printers exit
path.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Clean the maintenance kit wiper blade or
replace the maintenance kit.
Complete. Go to Step 3.
3 1. Check the exit area, exit frame, the
preheater, maintenance kit, and the
printhead (including the paper release blade)
to see if there is anything touching the drum
assembly.
2. Reseat any printer component interfering or
touching the drum assembly.
If there are streaks on the front side only of a
2-sided print, the preheater may be scraping
ink off the print.
2. Look for ink shavings along the streaks on
the printed paper.
3. Clean the preheater using the Control Panel
Remove Print Smears function.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Possible weak or missing jet. Print the weak/
missing jet test print from the Control Panel,
see "Weak/Missing Jet" on page 5-33.
Complete. Go to Step 6.
6 1. Possible discolored jet. Print the solid fill test
print, see "Black, Red, Green, Blue, Cyan,
Magenta, and Yellow Solid Fills" on
page 5-40.
Complete. Go to Step 7.
7 1. The X-axis drive is not functioning correctly.
If the X-Axis Drive does not move the
printhead smoothly and evenly during
printing, vertical lines appear on the print.
For information about X-Axis Drive
problems, see "White Stripes (Pinstripes)"
on page 5-30.
Complete. Go to Step 8.
8 1. Smears on a duplex print can be caused by
the paper preheater operating at a
temperature that is too high or debris is in
the duplex roller or duplex paper path
guides.
2. Run the service diagnostics Duplex Path
test to check the paper preheater’s
temperature.
3. Is the operating temperature within the
correct value range?
guides.
temperature.
Replace the
preheater.
Replace the
electronics
module
Hope this helps
3. Clean the paper release blade.
May 20, 2009 | Xerox Phaser 8560N Laser Printer
Smearing of the print-out
u need to open the printer assembly remove the paper and print again
Feb 24, 2009 | Samsung CLP 300 Laser Printer
Vertical toner smear-off in all colours
Looks like the ridges inside the cartridge are catching. Here's a solution;
http://www.ahfx.net/weblog.php?article=133
Dec 12, 2008 | Dell 3100cn Laser Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP-610ND + Demo Laser Printer Logo
426 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
