Question about Remote Starter with Keyless Entry
When system is plugged in and i use my key half crank kicks truck
When system is plugged in and i use my key i go to half cycle with my key and the starter kicks on. Then the module clicks 3 times and this loud sound like a vacuum running or the starter is still engaged? please help reslove this never happened before
    Problem Solver:
  • 7 Answers
If you have the manual at hand, put key in ignition and turn to the on and off position fast as you can and then push button. it should not rrespond because thats resets the alarm, follow manual on how to reprogram! hopes it helps out. I have bulldogs rs 1200 and trying to unlock my doors via keypad. locking them with no problem
Posted on May 14, 2010
Truck will not start, cranks but no start. have changed coil,plugs,and wires did run after part change , but now no start ?
When the key is in the run position you should hear the fuel pump kick on for 2 seconds immediately.
Nov 11, 2015 | Cars & Trucks
Hear pump kick on an it starts up an shuts off after a few seconds
Fuel system may have a problem at fuel filter, or pump is shutting down. Make sure you have spark after engine stalls( DO NOT TURN KEY OFF ). If you do turn key off restart let stall happen do not turn key this time. Pull a spark plug wire at spark plug. Put a spark plug into that end of the spark plug wire. Ground the base of the spark plug on a good none painted placed so that you can see the spark, then you turn the key to crank watching for sparks at the very end cap of the spark plug. My son has a 2013 Harley, I think this fill fix your problem, Lee.
Feb 09, 2014 | Harley Davidson Motorcycles
Bobcat s185
Make sure your battery is in good condition. It sounds like your glow plug cycle is taking all of the battery power and after the glow plugs kick off then you have enough power to crank the engine.
Apr 26, 2013 | Cars & Trucks
Ford explorer starting problem
check coilpack wires plugs. its a elc problem
Jan 22, 2013 | 1998 Ford Explorer
Recoil starter kicks back on 4 cycle engine and is hard to start can i fix this myself and how
most of the time when they kick back the key on the flywheel where the flywheel meets the crank shaft the key shears
Jun 19, 2012 | Briggs & Stratton Garden
I put the key in, turn to the second notch, the fuel indicator goes up to where it should be( bit under half) then goes back to below red and the low fuel light goes on( I know for a fact there should be...
hey there, your fuel pump seems to be bad. it will keep pressure while it gets that initial key turn as all fuel pumps kick in then but then loses pressure and doesn't kick in when pressure goes down. if the vehicle doesn't turn over try to tighten the terminal connections. good luck!
Feb 10, 2011 | 2003 Pontiac Montana
How do i get to the back three spark plugs
The check engine light ,has to do with ,is the gas cap tight? or the engine is burning RICH and the computer kicks it LEAN and then it kicks back RICH ,then it doesn't know what to do so it puts the check engine light on! it is ok to drive,fuel mileage may be lower. in a lot of cars it has to do with" ignition key cycles" put the key in ,turn it on crank it let it run,turn off ,take key out ,that is one cycle i know with some cars its 20, and some others its 54,your car may have what is called a OBDII .,plug ,under the dash ,a code reader ,could read the code and clear them ,THERE is something else ,that may work with my skyhawk,buick to clear code i could unplug the ---- negative side of the battery and wait 3 minutes and tighten it back on,you'll have to reset your radio
May 03, 2010 | 1997 Oldsmobile Cutlass Supreme
Your Bulldog remote starter has lost it's internal programming. That particular brand uses el cheapo components that are very static sensitive, therefore caausing them to lose the internal programming. Unbfortunately it can only be repaired by sending it back to the mfg.
Mar 17, 2010 | Remote Starter with Keyless Entry
1999 GMC Suburban Wont Turn Over
It sounds like you have a security problem, I had the same thing it would fire and run for half of a second and then that was it if anything at all. Had the security system rebooted, now it starts and runs fine.
Jun 07, 2009 | 1999 GMC Suburban
Remote Starter with Keyless Entry Logo
131 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
baire
john h
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
