Question about ViewSonic VA902b 19" Monitor
Screen won't stay on
I turn on my computer and monitor but the monitor only comes on for a second, the green on lite stays lite but nothing on the screen ? bad capacitor maybe?
  • 3 more comments
  • Anonymous Apr 02, 2008
    Hi, I have 2 ViewSonic VA902b monitors that have the same problem. When you turn them on the video on the screen will flash on for a moment. Could It be the backlight? The were only manfactured in Mar 06 so they may still be in warranty. What do you think? Give me the technical explaination, I used to repair consumer electronics. Thanks, Bob
  • navarac Sep 11, 2008
    Has anyone gotten a resolution to this issue. I have 4 VA902b monitors that are doing the same thing.
  • Anonymous Nov 02, 2008
    Nothing visibly wrong inside, but same problem here.
  • mclambert Nov 09, 2008
    Same problem... flashes on for a second the blank. Computer still recognizes monitor attached.
  • Anonymous Feb 08, 2009
    Likewise: Boot, monitor flickers, blank screen.
  • 1,684 Answers
This is a common problem with LCD monitors after a few years of use. The capacitors in the power supply board start to fail and this prevents the monitor from starting up correctly. Sometimes you get a picture and then it goes black. On some units you can keep pressing the power button and after several power up cycles the monitor will work until you turn if off. These symptoms are all common with capacitor failure. The monitors are well out of warranty now so Viewsonic will not cover the repair cost. But the repair is very easy to do yourself. You just have to replace the 6 power filter capacitors on the power supply board. Here is a link to additional information on this repair.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
I hope this helps, I have repaired over 30 of this model with the same issue.
Posted on Jun 21, 2012
How do you fix the backlight inverter?
Posted on Nov 13, 2008
    Champion:
  • 293 Answers
Hi...Guys,
Yeah...you're right! your backlight inverter are burnt out. Most likely due to over heating capacitors.
Good lucks!
Posted on Sep 21, 2008
I had the same problem and called Viewsonic (www.viewsonic.com). Bought mine in July '06 and to my surprise it's still under warranty. The warranty goes for 3 years so even though shipping is my cost, they'll fix or replace it with a same/similar model.
Posted on Jan 05, 2009
I had a chat session with Viewsonic and they agreed to fix all 4 of mine under warranty. No real hesitation on their part - maybe it's a known problem.
Posted on Sep 22, 2008
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
Black screen green lite on/flash right green lite off
The problem on your monitor is a bad power supply. We you can solder you should be able to repair it. If you check our site at :
www.ccl-la.com/badcaps.htm We have a monitor repair section with dis-assembly guides and repair procedures. I will post a Hanns-g guide tonight. This will show how to open and repair the monitor. We also have a repair parts kit available. If you don't want to do the repair yourself then we can do it for you, just email me if you have questions or wan tus to do the repair for ou.
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Aug 05, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Sony laptop with dead screen
Try this: Unplug your computer from electricity, remove battery, then, press and hold the power button for about 30 to 60 seconds, leave battery out connect to power then, try to restart
Let me know if it works.
good luck
Apr 06, 2009 | Sony VAIO Notebook
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
KDS usa flat screen monitor model 780 2003
Shine a light on the screen and see if the Icons are there.. Could be a CCFL bad or inverter problem..
Jan 25, 2008 | Gateway FPD2275W LCD Monitor
ViewSonic VA902b 19" Monitor Logo
1,124 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
