I have a 3020i and one channel is very distorted. The other channel is crystal clear.i have changed all speaker leads/interconnects round and it is definitely the right hand channel that is distorting.
    President:
  • 1,851 Answers
Unplug the power, open the case and try to locate some electrolytic capasitors is series with the audio at the channel with the problem. One of them must be blown.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 11, 2010
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Troubleshooting tv problems
Try Auto rescanning your tv channels.
If still same then maybe aerial needs adjusting slightly
Aug 10, 2014 | Bush Universal Flat Screen TV Swivel Mount
My DJM 400 one of the outputs is louder and has distorted sound what do I do?
First verify that one channel is bad by swapping the output leads and seeing the bad audio comes from the other speaker. Assuming it does, you probably have a bad output driver on one side.
This can happen if one powers part of the system from different receptacles in a venue and electrical disturbances destroy one or more audio interconnects. ALWAYS power ALL interconnected equipment from the same source, even if you have to run an extension cord between power amps and the mixer.
You will probably need to take the unit for repair. The parts cost should be nominal, however labor could cost a bit.
Find out is SAME distortion is present in the headphone output. The circuitry shows a bunch of muting transistors and one of them could be bad... but we can do some troubleshooting externally with testing at headphone jack, etc.
Oct 14, 2010 | Pioneer DJm 400 Professional DJ Mixer
Akai am-u01 righthand channel sounds distorted/blown please can you tell me what components on the board to check/replace the left channels fine i have allready re-wited most of the board but cant single...
You can try swapping the speakers over to see if the fault goes to the other channel. Remove the speaker leads from the input on the right channel and put them into the left channel input after removing the leads from those terminals, and if the fault goes there as well, then the problem is in your right channel speaker
Apr 13, 2010 | Audio Players & Recorders
I want to know about the car speaker for ford focus 2004 model 1.4lx
O.K hear is the deal on most factory car Speakers their not very high wattage they don't need to be, see Distortion level has as much to do with Sound Quility as Power you don't need a lot of Power if the unit is crystal clear this is usely done thru Low Wattage because of Voltage humm and grounding issues most of your Factory Units have great to Exceptional Ground and very low levels of distortion 0.2 % or Lower that is the reason they sound so Great there crystal clear they won't blow Your Windows out but you can hear every little chim or Musical Note that the system can put out.power is Impressive as far as looks but not nessasary as far as great Sound untill you get to your very high end cars that have custom installed systems most are Low Voltage Low Distortion Units and Speakers
Jul 25, 2009 | Car Audio & Video
Suddenly, my outdoor speakers sound kind of "muffled"
If these speakers are two or three way speakers, it is possible that the tweeter(s) are blown in them.
Try and remove cover to check.
If the sound is not distorting, but just flat and muddy its the tweeters.
Put the other ones on this channel, to make sure it is not the amp.
Jun 13, 2009 | Insignia Simulated Rock Outdoor Speakers...
Connect subwoofer etc to nad 3020I stereo amplifier
Hi Info
You can use a 2 x male RCA to RCA female adaptor lead(what you need to ask for)  like this one 4d0dcde.jpg
use it to jumper your pre-out/main in connection on the rear, and connect an RCA lead to the Female socket on the adaptor lead. That will get you going. You can get them most places that sell electronic bits and peices. I am happy to answer any questionsa you may have
regards robotek
Mar 05, 2009 | NAD C320 2-Channel Amplifier
Amp won't put out sound
A lot of Amps come with fuses as a safety mechanism so you don't blow the speaker and/or internal components in the case of a power surge etc. Check for a blown fuse. Sometimes they have a fuse holder in the back of the amp and it is labelled "fuse" which cetainly makes it easier to find. Hope this works and helps.
Nov 17, 2007 | Prime 40 Watt 2 Channel Lead Electric...
50 people viewed this question
 Grubhead
Grubhead
