Question about Canon imageRUNNER 1023iF Black and White Copier
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
  • 1,219 Answers
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
Posted on May 11, 2010
2 Suggested Answers
lahen01
  • 63 Answers
SOURCE: The screen says the Paten glass needs to be
use isopropyl alcohol on a cloth and clean the thin strip of glass on the left side under the document feeder, if there is ink, white out or paper dust it will show up on the copies as a black line across the page. (display dirty adf message) turned to off will stop the message from coming up on the screen, like 2son said it is under additional functions.
Posted on Apr 05, 2010
I have a Wheelwriter from 1986 and the paten has a big **** in the roller from one end to the other. Is there any repair for this?
The platen is easily replaced. We can sell you one for 35.00 plus shipping but we must know the length of the black roll they are not all the same.
DickyO
Aug 08, 2010 | Lexmark Wheelwriter 5 Series II Typewriter
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
A mailing label is stuck to the paten. How can I get it off? It's stuck behind the ribbon. I've been using tweezers to get it off, but just comes off in little pieces. I can't turn it on because it...
On both ends of the platen are black latches squeeze them together and pull the platen out. Now you can clean the debris out of that area. If you remove the silver paper tray note how it is installed for replacement. Re-insert the platen be sure to line up the latches with the side frames and push down firmly to snap into place.
DickyO
Feb 09, 2010 | IBM Wheelwriter 30 Typewriter
We have a red line thru our scans? I have cleaned everything it says to clean?
red line? this is a black & white
is the line apear only when you scan ?
try and make a copy of the glass if you do not see line .than you problem is that **** glass that scanner uses.IT MAY HAVE WHITE OUT OR INK CLEAN IT .it long thin along the the paten glass
hope that help
Nov 13, 2009 | Kyocera Copystar CS-1820 Black and White...
My copier says Paten is open closet paten. but everything is closed. what do I do?
Each lid has its sensor. Usually this salients on lid, you it is necessary attentively to look, what salient overlays the sensor salient on lid, can be comes short quite little, arouse to press the lids by turns.
Unless it is got, follows to apply to service, sensors mortality, is violated contact to sensor, the sensor has forfeited its place.
Oct 06, 2009 | Office Equipment & Supplies
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
HP Laser Jet 2840 Printer
If it's scan and copy only and not when you send a job from the computer your solution is easy to remedy. Try going into the menu located on the printer to info menu. Scroll down to conguration page and click the check button. When the printer prints, if the line is not on the page you simply have ink or white-out on the scan glass for the ADF (auto doc feeder).
To clean the ADF glass, lift the top lid to expose the glass. There are two peices, 1 large full size and one strip peice. If your getting the line when using the auto feeder (without lifting top) pay close attention to the strip of glass. When a document is auto-fed it moves the original past the strip of glass. A dot (pen mark or white-out) will appear as a line on your final copy.
Clean well with windex or similar glass cleaner. PUT THE CLEANER ON THE RAG THEN THE RAG TO THE GLASS. Don't spray the glass as it's easy to get it into cracks where to don't want it to fall on an electronic part or board below the glass edges. While you at it, clean all the glass.
Test by making a copy of a "BLANK" sheet of paper with one small line to give you postion clues. First by putting it on the glass. Clean everywhere on the large glass that shows a mark on the page (except the one you purposely put there). The mark will help you locate where to clean. (example - 1" below and 2" over from your intentional mark) It also helps you identify top of page from bottom.
Once that is done do the same thing using the original in the ADF. Simply measure in from the edge of the page on the copy and find the corresponding spot on the small strip of glass.
IF YOU SHOULD BE GETTING THE LINE IN ALL FUNCTIONS, PRINT, COPY MANUALLY, AND COPY WITH ADF. Check the toner cartridge, most likely black for damage on the cartidge drum. The cartridge drum can be quickly viewed by flipping the shutter open (the part with the HP logo and part number printed on it). If there is a line, replace the cartridge.
Hope that helps you. If so hit it with a FIXYA!
Thanks,
Aug 30, 2008 | HP LaserJet 2840 Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Canon imageRUNNER 1023iF Black and White Copier Logo
366 people viewed this question
old marine
old marine
