Question about Canon ImageRUNNER 1670F Copier
It keeps defaulting to the copy function - Canon ImageRUNNER 1670F Copier
  • 1,219 Answers
Wich model, like above?
If you mean that the display is " normal" but you cannot gave any order to copier, like when you press any button nothing hapens - then first turn off and on - if not OK - check if some of buttons are "stucked", try it to unlock it.
hope that helped
pls. rate
Posted on May 11, 2010
Can't get icom a6 radio unlocked
Copied this from their manual:
The lock function prevents accidental frequency changes and accidental function activation. q Push (looks like f) , then push [7• ] to turn the lock function ON. •" " appears. (looks like f) To turn the function OFF, repeat step 2 above. •" " disappears.
http://www.icomamerica.com/en/products/avionics/handheld/a6/default.aspx
Sep 18, 2016 | ICOM Informatique Radio Communications
I need to restore my computer using the Function keys and do not remember which Function key(s) to use
If you are certain that there is a recovery partition with a factory default image then your user manual should include the instructions on how to access it.
HP normally uses a backup and recovery software rather than a recovery partition with a default image. This setup requires that you make restoration discs before using the computer in case something goes wrong.
Alternatively, you can keep restarting the computer and hit a different function key each time in an attempt to access a recovery program.
If you own a copy of Windows you can also just put in the disc and install Windows to your C: drive and over-write the existing installation.
As a last resort, you can order a set of recovery discs from HP's Customer Support.
Jul 06, 2012 | HEWLETT-PACKARD Compaq DC5850...
The copy function on this unit is not operating correctly. When attempting to copy a page, it only copies a small portion of the page.
Try to reset the printer to its default factory settings. On the printer operator panel, press Setup button > Defaults > Set Defaults > Use Factory > OK button. You will then be asked to enter some printer information (i.e. date, time, fax number, etc.). After entering these information, try to print again.
Aug 12, 2011 | Lexmark X6675 All-In-One InkJet Printer
When using the copy function, the unit only copies a portion of the page
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
Remove copying codes
F-5 service code 42 F5-42-0 set 42 to"0" no accounting,51-0 no copy account,52-0 no FAX account
To enter service mode,Function,copy, "3" simtameously default password 00000000 if changed willrequire a service technican who last service machine
Mar 30, 2010 | Panasonic Workio DP-1820E Copier
all copiers by default go to copy, this can be set usually in operator/user parameters
Mar 17, 2010 | Canon ImageRUNNER 1670F Copier
Minolta Dialta Di 350f how do you change the display language
1. User's Choice Function Setting Procedure
<Procedure>
1. Press the Utility key.
2. Touch the “User’s Choice” key.
3. Select the appropriate screen from the menu.
4. Select the appropriate function.
5. After the settings are complete, touch the “Enter” key to validate the settings.
2. User's Choice Function Tree
Memory Recall
User’s Choice 1/6 Mixed Original Detection
Language Selected **************** SEE THIS ONE
Original Copy Default
Auto Paper/Auto Size
User’s Choice 2/6 Drawer Priority
Special Paper
Multiple-in-1 and Booklet Copy
Zoom
Auto Panel Reset
Energy Save Mode
User’s Choice Mode User’s Choice 3/6 Plug-In Counter,ID Key Reset
Auto Power Off
LCD Back-light Off
4in1 Copy Order
Density Priority
User’s Choice 4/6 Default Copy Output Levels
Priority Density
Output Priority
Intelligent Sorting
Output Tray
User’s Choice 5/6 “Small” Originals
Scanner Dry
User’s Choice 6/6 Density (ADF only)
May 26, 2009 | Konica Minolta Office Equipment & Supplies
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Panafax dx-800
Press Function, then 7
Press 4, then Copy/Set
(it should ask for a fax parameter, the one for the key sound is 010)
Enter "010", then Copy/Set
Set the parameter to "1" for Off, then press Copy/Set
Press Stop to exit back to the default screen
Jul 23, 2008 | Panasonic Panafax DX-800 Plain Paper Laser...
Canon ImageRUNNER 1670F Copier Logo
old marine
old marine
