Question about Sony Playstation 3 (PS3) Console
My dual shock 3 do not sync with my ps3. When I push ps button to sync it plug on the usb cable I got the no. 1 and 2 light than stay on. Thanks!
  • 219 Answers
At the top back part of the controller there is a little pin hole button. With the console on, press the PS button and then the little button inside the pin hole to sync the controller.
If i've helped you please give me a good rating.
V/r,
Don
Posted on May 11, 2010
Just hooked up my PS3 for the first time. Can't get remote to work...
There is a tiny button on the reverse of the controller, press this with a paperclip and it should sync first time.
Feb 06, 2012 | Sony Playstation 3 (PS3) Console
I bought a dual shock controller but the little reset button at the back doesn't have a button in it, so can't reset. What can I do. The lights are blinking when I plug in the usb cable, but that's it. ...
You need to use a paperclip to press the reset button. Unfold the paperclip and push it into the reset hole which is to the right of the screw above the sticker on the back of the controller.
Once you have reset it, plug in the USB cable and press the round button to sync with the PS3.
Hope this helps,
Chris
Mar 17, 2011 | Sony Dual Shock 3 Controller for...
I have a ps3 dualshock 3 controller that wont connect. i have taken it apart to check and see if anything was wrong with the inside, but i saw nothing. When i put it back together, i tried pressing the ps...
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 13, 2011 | Sony Dual Shock 3 Controller for...
My dual shock 3 is not lighting at all. i tried connecting it on my ps3 and laptop using different usb cables but still when i press the ps button it didn't ligh
This usually happens when the controls have lost most of their power.
Try leaving your controller plugged in (charging)overnight or for like 2 hours. (Controls only charge with the PS3 ON).
Jan 18, 2011 | Sony Dual Shock 3 Controller for...
The controller will only connect if its plugged in a usb, if i disconnect it continually flashes all the lights and wont sync with the system?
Plus your controller in to the usb port in your ps3 once it connects press the PS button and it will sync and voila it's done. If you want to change it to a friend's console do the same with their console
Mar 21, 2010 | Sony Dual Shock 3 Controller for...
My dual shock controler just doesnt turn on, no red light, nothing! what should i do?
I presume you have charged it up with USB cable plugged into ps3..if so you could try pressing ps button while connected.. if still no light..replace handset re-chargable battery..!
Feb 26, 2010 | Sony Dual Shock 3 Controller for...
All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Aug 30, 2009 | Sony Dual Shock 3 Controller for...
Dual Shock 3 Doesn't seem to work at all
i have the perfect solution...
step 1- plug usb into controller, make sure the system is off
step 2- press thee reset button on the back of the controller then turn your system on with the systems on-button
step 3- once the system is on, press the ps button.
step 4- remove the usb and then pres ps again
step 5- it workz, gud lukk!
Apr 12, 2009 | Sony Dual Shock 3 Controller for...
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Problems connecting a ps3 controller
Here's how to connect it tou your ps3. Mine works perfectly guys.
1. Turn your ps3 off without the USB key given with the controller
2. Make sure your controller is off.
3. Turn on the ps3
4. Turn on the controller
5. Press on the sync. button of your controller.
6. Plug the USB key into one of your ps3's port
7. When the light above your controller starting to flash slower, just pess the home button and your controller will be sync.
You can't turn on the ps3 with this controller. So turn it on manually than press the home button of the controller to turn the controller on.
If my post doesn't solve your problem, I really don't know how to solve it. I managed to connect mine so I hope it'll be the same for you!
Sorry for my bad English folks! You know... french people =S
Jan 03, 2009 | Intec PlayStation 3 Turbo Shock III...
Sony Playstation 3 (PS3) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
