Question about Avanti 3.4 cu. ft. / 96 liter Chest Freezer CF96
Freezer not freezing after electric plug went out. Plug was out for a day or two before I noticed it. When I plugged freezer back up will not get cold.
  • 523 Answers
Check the over load and relay on the compressor
Posted on May 11, 2010
2 Suggested Answers
  • 389 Answers
SOURCE: Freezer not freezing after electric plug went out.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Freezer is too hot and flashing DEF - how do I get back to Freezing mode?
Either the freezer needs to be defrosted or it went into defrost and didnt come out. So most likely your defrost system has failed. A good way to check this will be to unplug freezer for about a day or 2, and let it defrost manually. Should begin working properlt again when plugged back in . The problem will return suggesting your defrosy system has failed.
What is the make and mod of the freezer so i can tell you how to access it.
Feb 20, 2011 | Randell Freezers
Freezer not freezing after electric plug went out. Plug was out for a day or two before I noticed it. When I plugged freezer back up, will not get cold.
Mar 17, 2010 | Avanti 3.4 cu. ft. / 96 liter Chest...
We have a 20.3 cubic feet Kenmore upright frost free freezer we purchased in May 2003. We noticed the meat was beginning to thaw one afternoon. We hit the quick freeze button and that seemed to fix the...
This sounds like a bad thermostadt, since the quick freeze button does work. But it should be much colder than 32 degrees. It may also be the motor, since it runs for brief periods of time after plugging it back in.
I'd say best bet here is to call a repairman. (sorry...)
May 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My brand new freezer wont freeze
I would plug it into a different plug in - not one that is on the same circuit that it is plugged into now. If the plug in is working for other things, it still may be bad and not able to handle the load of the freezer. If your freezer will not work on a completely different circuit, then there could be something wrong with the freezer, but it is not likely since two of them should not be bad. Seems to me more like an electrical problem in your location. Hope this helps you, Rick
Apr 28, 2009 | GE Freezer  14.8 Cu. Ft. Manual...
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
Dec 17, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Avanti 3.4 cu. ft. / 96 liter Chest Freezer CF96 Logo
113 people viewed this question
Top Avanti Freezers Experts
Dennis Boxerman
tom wright
tom wright
Steve F
Are you an Avanti Freezer Expert? Answer questions, earn points and help others
