My printer was working fine until I moved. Once I
My printer was working fine until I moved. Once I unplugged it & moved to new house it won't even turn on.
    Champion:
  • 224 Answers
Check the rating is correct. if the plug has a fuse check that. try a different wall socket
Posted on May 11, 2010
Can anyone tell me why my Brother MFC-J630w wont turn on. I was using it earlier. When I unplug it & plug it back in, the light doesn't come on. It just makes a ringing sound.
1. Unplug the power code then plug it in again. Do this where it plugs into the wall and also do it where the cord plugs into the printer.
2. If the printer is plugged into a power strip, switch to off then to On.
3. If nothing else is plugged into the same wall outlet or power strip, plug in a lamp, for example, to see if it works. If not, the circuit breaker for the wall outlet probably needs to be reset. Circuit breakers are in the main electrical panel/box for your house. There should be one that is moved to the left. Push all the way to left and then push to right firmly until it makes a loud CLICK.
May 18, 2014 | Brother MFC 490cw Color Inkjet...
What is wrong when my car won't move until it reaches about 2500 rpms,
It could be if transmision is automatic ..the (0) ring inside the trans and if the trans is stick shift u need a clucth
Jul 25, 2012 | Toyota Cars & Trucks
Ge refrigerator won't cool. compressor doesn't come on
The compressor is gone, only option replacement.
Apr 18, 2012 | Televison & Video
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
Cartridge housing will not certre to change cartridge
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Apr 10, 2011 | Lexmark Z2300 InkJet Printer
Canon MP530 error code - "Check Printer 6500"
Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Just got new all in one comp. and my c6280 printer won`t work?
Not very specific. However, I would suggest that you go to START, SETTINGS and select and remove you printer. Then goto START< SETTINGS, CONTROL PANEL, Remove & Add(xp) [Programs & Features(vista). There install all programs relating to the printer.
Before reinstalling the printer, be sure to UNPLUG the USB cable. run the install disk.....do not plug the USB in until prompted. That should fix your problem.
Good luck
Feb 17, 2010 | HP C6280 All-in-One Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
60 people viewed this question
jasbo
jasbo
